02-07-2015, 02:23 | #1 (permalink) |
No Life Poster Join Date: Mar 2006
Member: 240043 Status: Offline Thanks Meter: 78 | i9500 4.4.2 imei null/ null make efs repair in download mode, then try wite service imei, show writing imei failed Bienvenido en Octoplus/Octopus Box Samsung software versión 1.8.2 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM15 Modelo seleccionado: GT-I9500 Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Modelo del teléfono detectado: GT-I9500 Fecha de creación del firmware: Fri Feb 28 21:23:39 KST 2014 PDA version: I9500UBUFNC1 CSC version: I9500UWAFNC3 Versión del SW: Unknown IMEI del teléfono: Unknown Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM15 Modelo seleccionado: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM15 Modelo seleccionado: GT-I9500 Modelo del teléfono detectado: GT-I9500 Fecha de creación del firmware: Fri Feb 28 21:23:39 KST 2014 PDA version: I9500UBUFNC1 CSC version: I9500UWAFNC3 Versión del SW: Unknown IMEI del teléfono: Unknown Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Write IMEI failed ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM15 Modelo seleccionado: GT-I9500 Modelo del teléfono detectado: GT-I9500 Fecha de creación del firmware: Fri Feb 28 21:23:39 KST 2014 PDA version: I9500UBUFNC1 CSC version: I9500UWAFNC3 Versión del SW: Unknown IMEI del teléfono: Unknown Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Archivos de programa\Octoplus \Octoplus_Samsung\BACKUP\Security-GT-I9500-Unknown06-02-2015_ 20-07-24-.asec file Cheking security type... Old security type is detected Deactivating MSL... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... MSL deactivate successfully Executing exploit... Exploit has been executed successfully IMEI antiguo: Unknown IMEI nuevo: 352993-05-005457-6 Repairing IMEI ... Unknown security Write IMEI failed ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM15 Modelo seleccionado: GT-I9500 Selected file must be *.cert Writing Certificate failed |
02-07-2015, 06:58 | #2 (permalink) |
Freak Poster Join Date: Oct 2014 Location: black house
Member: 2280366 Status: Offline Thanks Meter: 19 | hi bro your modem is damaged (baseband unknowen)and you must first repair it after that you can repair imei. for baseband you must flash phone with other firmwares until the baseband is come back. you can check baseband in phone:setting:about phone:baseband after baseband you can repair imei |
02-07-2015, 09:26 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Yes, mr. saeed-vaker is right, as You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair EFS" and "Repair IMEI" (or Wipe Security and Write Cert) operations. It is not possible to repair IMEI (or Write Cert), if phone's modem part is damaged. | |
