06-12-2015, 20:52 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Prizren
Member: 841080 Status: Offline Thanks Meter: 177 | I9500 emergency calls only!!! [Solved] Last edited by Octopus box; 06-15-2015 at 09:41. |
06-13-2015, 10:00 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to do exactly the next: 1. Make Repair EFS. 2. Re-flash the phone. 3. Make Repair IMEI (write service IMEI from the Software list, not any IMEI). 4. Re-flash the phone again. 5. Re-start the phone, search and select network manually. 6. Post here full Software log with all of your actions and say the result. |
The Following 4 Users Say Thank You to Octopus box For This Useful Post: |
06-14-2015, 07:04 | #3 (permalink) | |
Member: 841080 Status: Offline Thanks Meter: 177 | Quote:
With wich version sugest to flash 5.0 or 4.4.2 , phone when come to me had 5.0 . | |
The Following User Says Thank You to svchost For This Useful Post: |
06-14-2015, 07:27 | #4 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 427344 Status: Offline Sonork: 100.1666688 Thanks Meter: 213 | on 4.4.2 i tested one set today working fine only and only with help of octopus team 1. Make Repair EFS.with octopus 2. Re-flash the phone. 3. Make Repair IMEI (write service IMEI from the Software list, not any IMEI).used super imei but was unable to write it with octopus instead used other box 4. Re-flash the phone again. 5. Re-start the phone and wow network full thanks octopus team |
The Following User Says Thank You to kk2sna For This Useful Post: |
06-16-2015, 09:09 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Unfortunately, if You reflash the phone after Service IMEI was written, Network can be unavailable (not active). You can try to repair phone's IMEI via "Write Cert" operation, then You can upgrade phone's firmware without a problems. |
02-22-2016, 20:42 | #8 (permalink) |
Freak Poster Join Date: Jun 2013 Location: india tirupur tamilnadu
Member: 1962832 Status: Offline Thanks Meter: 199 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Thu Feb 13 20:33:19 KST 2014 PDA version: I9500XXUFNB3 CSC version: I9500SERFNB3 SW version: I9500XXUFNA6 Phone IMEI: 004999010640000 Phone SN: RF1D45EJGGR Android version: 4.4.2 (KOT49H) Rebooting phone in Download Mode... Phone successfully rebooted in Download Mode. Performed by 2.2.1 software version Selected firmware file: I9500XXUFNB3_I9500SERFNB3_I9500XXUFNA6 _HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: GT-I9500 Selected file: C:\Documents and Settings\a1mobilecare\My Documents \Downloads\Cert-GT-I9500-358851056213287_RV1D969EZT.cert Detected phone model: GT-I9500 Firmware compiled date: Thu Feb 13 20:33:19 KST 2014 PDA version: I9500XXUFNB3 CSC version: I9500SERFNB3 SW version: I9500XXUFNA6 Phone IMEI: 004999010640000 Phone SN: RF1D45EJGGR Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Writing Certificate failed Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: GT-I9500 Rooting phone failed. Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: GT-I9500 Rooting phone failed. Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9500 Rooting phone failed. Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9500 Selected file: C:\Documents and Settings\a1mobilecare\My Documents \Downloads\Cert-GT-I9500-358851056213287_RV1D969EZT.cert ADB server killed. Detected phone model: GT-I9500 Firmware compiled date: Thu Feb 13 20:33:19 KST 2014 PDA version: I9500XXUFNB3 CSC version: I9500SERFNB3 SW version: I9500XXUFNA6 Phone IMEI: 004999010640000 Phone SN: RF1D45EJGGR Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9500 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Rebooting phone failed. Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9500 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Rebooting phone failed. Performed by 2.2.1 software version thanks octopus team............... |
The Following 2 Users Say Thank You to a1mobiletirupur For This Useful Post: |
10-07-2017, 08:48 | #10 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Lebanon
Member: 1657517 Status: Offline Thanks Meter: 74 | thanks Sir, done emergency calls only follow your oparetion ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: GT-I9500 Searching for a phone. Please wait... Phone found. Detected phone model: GT-I9500 Firmware compiled date: Mon Feb 17 17:39:24 KST 2014 PDA version: I9500XXUFNB4 CSC version: I9500OJVFNC1 SW version: I9500XXUFNC1 Phone IMEI: 357504051787646 Phone SN: RF1D45EJGGR Android version: 4.4.2 (KOT49H) Sales code: KSA Country: KSA HW platform: exynos5 HW Chip: exynos5410 HW Modem: XMM6360 Codename: ja3gxx Performed by 2.6.0 Software version. |
