01-10-2014, 17:24 | #1 (permalink) |
Product Manager Join Date: Apr 2009 Location: BD,BH,CN
Member: 1004001 Status: Offline Sonork: WhatsApp+971506319003 Thanks Meter: 448 | i9500 imei null How can i Repair it please help me octopus team . |
The Following User Says Thank You to UNLOCK PARK ® For This Useful Post: |
01-10-2014, 17:36 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. At first, please connect the phone, make "Read info" and post here Software log with phone's info. To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. |
01-10-2014, 18:02 | #3 (permalink) | |
Member: 1004001 Status: Offline Sonork: WhatsApp+971506319003 Thanks Meter: 448 | Quote:
Selected port: COM121 Selected model: GT-N7100 Port is busy Searching for a phone. Please wait... Phone found. Firmware compiled date: Tue Apr 23 23:08:00 KST 2013 PDA version: I9500XXUAMDK CSC version: I9500OJVAMDK SW version: Unknown Phone IMEI: Unknown Android version: 4.2.2 (JDQ39) | |
01-10-2014, 18:05 | #4 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | As I see from this log, modem part is damaged in your phone: Quote:
At first, try to re-flash the phone with different firmwares and check whether modem is correct (not Unknown) and only then perform "Repair EFS" and "Repair IMEI" operations. Also, please, be attentive and always select correct device model: Quote:
01-10-2014, 18:19 | #5 (permalink) |
Member: 1004001 Status: Offline Sonork: WhatsApp+971506319003 Thanks Meter: 448 | Platform: Samsung Android Selected port: COM121 Selected model: GT-I9500 Port is busy Searching for a phone. Please wait... Phone found. Firmware compiled date: Tue Apr 23 23:08:00 KST 2013 PDA version: I9500XXUAMDK CSC version: I9500OJVAMDK SW version: Unknown Phone IMEI: Unknown Android version: 4.2.2 (JDQ39) Can you gave me any 100% file link . |
01-12-2014, 15:28 | #9 (permalink) |
Member: 1004001 Status: Offline Sonork: WhatsApp+971506319003 Thanks Meter: 448 | Welcome to Octoplus/Octopus Box Samsung software version 1.4.4 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: I9500UBUAMDK_ZTOAMDK_Brazil_Android_ 4.2.2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9500 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Platform: Samsung Android Selected port: COM121 Selected model: GT-I9500 Port is busy To put GT-I9500 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Platform: Samsung Android Selected port: COM121 Selected model: GT-I9500 Reading info, please wait... Detected phone model: GT-I9500 Firmware compiled date: Wed Apr 24 23:35:46 KST 2013 PDA version: I9500UBUAMDK CSC version: I9500ZTOAMDK SW version: Unknown Phone IMEI: Unknown Android version: 4.2.2 (JDQ39) |
01-12-2014, 19:25 | #10 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | As I see from this log, modem part is still damaged in your phone: Quote:
Try to write different firmwares from the Support Area one by one and check, whether modem is correct. If after of writing all firmwares, phone's modem part is still damaged, most likely, this is HW problem. | |
