09-15-2014, 19:45 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: gsmworld
Member: 757297 Status: Offline Thanks Meter: 36 | i9500 imei null help Selected port: COM202 Selected model: GT-I9500 ADB server killed. Detected phone model: GT-I9500 Firmware compiled date: Fri Apr 12 17:28:49 KST 2013 PDA version: I9500XXUAMDE CSC version: I9500ODDAMDC SW version: Unknown Phone IMEI: Unknown Android version: 4.2.2 (JDQ39) Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP \Security-GT-I9500-Unknown15-09-2014_11-33-56-.asec file Cheking security type... Old security type is detected Executing exploit... Write IMEI failed |
09-15-2014, 20:20 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. As You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform the "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. If after of writing all firmwares which You have, phone's baseband is still null (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). Last edited by Octopus box; 09-16-2014 at 06:33. | |
09-20-2014, 04:15 | #3 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Toronto
Member: 2244501 Status: Offline Thanks Meter: 16 | Solution: Flash 4.3 Firmware File with Odin from Sammobiles, Root using CF-autoroot, Instal Superuser 2.02 or towelroot, Then do Imei repair. If need help ask me |
