Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-07-2013, 13:34   #1 (permalink)
Member: 93292
Sonork: www.paypal.me/FGSM
Thanks Meter: 83
I9500 unlock problem
Direct Unlock
Root your phone manualy;
Connect powered-on phone to PC via Micro USB cable;
Install necessary driver;
Click "Unlock" button;
Follow software instructions (prompts).
Welcome to Octoplus/Octopus Box Samsung software version 1.2.7
To connect GT-I9300 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Developer options.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Connect usb cable to phone.
6. Go to dial window.
7. Enter *#9090# number.
8. Set speed to 115200.
9. Reboot phone.
10. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM3
Selected model: GT-I9500
Detected phone model: GT-I9500
Firmware compiled date: Tue Apr 23 23:08:00 KST 2013
Phone SN: RF1D64ZTQ1H
Android version: 4.2.2 (JDQ39)
Unlocking phone. It can take some time. Please wait...
Can't get superuser aceess. Please, repeat opperation once againe
and press "Allow" button on the phone every time when superuser
dialog appears.
Phone unlocking failed
Selected port: COM3
dialog appears.
Old 08-07-2013, 15:20   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,405
Please root the phone, try to perform unlock again and post results here.
Old 08-08-2013, 15:12   #3 (permalink)
Member: 93292
Thanks Meter: 83
so u dont have any solution because phone is rooted
Old 08-08-2013, 18:39   #4 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Hello, sure is rootted?, from the LOG phone isn't Rotted,
Max
Old 08-09-2013, 13:05   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
To root Your phone please carefully perform next steps:
1. Put phone into Download mode;
2. Connect phone to PC via Micro USB cable;
3. Install required driver;
4. Select Root_GT-I9500.oct firmware file;
5. Click "Write firmware" button;
Old 09-04-2013, 04:35   #6 (permalink)
Member: 1404366
Red face Same problem i9500
Hi a root the Phone but
Plataforma: Samsung Android
Puerto seleccionado: COM5
Modelo seleccionado: GT-I9500
Modelo del teléfono detectado: GT-I9500
Fecha de creación del firmware: Tue Jul 2 13:14:14 KST 2013
Phone SN: RV1D46EFZ9F
Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears.
La liberación del teléfono ha sido fallada
Can you help me
TKS
Old 09-04-2013, 08:17   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
ПолностьюHello.
As I see, your phone was not rooted completely:
Can't get superuser aceess. Please, repeat operation once againe and press "Allow" button on the phone every time when superuser dialog appears.
Please root the phone again and repeat the operation.
Old 10-11-2013, 13:52   #8 (permalink)
Member: 1085746
Sonork: 102030
Thanks Meter: 36
I can ton fiend This file Root_GT-I9500.oct firmware file
Old 10-11-2013, 14:35   #9 (permalink)
Member: 1146942
Sonork: 100.1587278
@ smt_mamun
Hello.
You can download firmware from Free Octopus/Octoplus Support Area from "Samsung/FOR UNLOCK AND REPAIR/" folder - just press "Go to Support" button on "Support & Options" tab in Software.
Old 10-11-2013, 15:26   #10 (permalink)
Member: 1459662
Thanks Meter: 152
after root you need go to settings in supersu and allow permissions
Page generated in 0.19015 seconds with 8 queries
