08-24-2016, 15:18 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | i9505 3g repair prob Selected port: COM41 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\NV-GT-I9505-24-08-2016_19-17-14-.nv file Writing NVM failed 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu. Performed by 2.3.3 software version |
08-24-2016, 15:25 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Try to perform the operation on different COM ports with enabled "Manual select" option. Post here result and full Software log your actions. |
08-24-2016, 15:36 | #3 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | latform: Samsung Android Selected port: COM1 Selected model: GT-I9505 Mode: Emergency Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM46 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM8 Phone connection failed Connecting to phone on COM65 Phone connection failed Selected action can’t be performed Performed by 2.3.3 software version |
08-24-2016, 16:48 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please make Factory Reset, then do the next: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Connect the phone directly to PC. 11. Perform "Read Info" operation on different COM ports with enabled "Manual select" option. Post here result and full Software log your actions. |
