04-18-2014, 14:15 | #17 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Sousse /trockadero/TUNISIA
Member: 193003 Status: Offline Thanks Meter: 46 | need our collaboration please pb i9505 imei null/null any way to solve this pb i post all nedded logger ----------------------------------------------------------------------------------- logger read info Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- logger repair security Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Detected phone model: GT-I9505 Firmware compiled date: Tue Jan 14 01:42:23 KST 2014 PDA version: I9505XXUFNA5 CSC version: I9505OXAFNA5 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Writing security backup, please wait... Phone will restart now ----------------------------------------------------------------------------------- logger Repair 3G/4G Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Repairing 3G/4G... Writing NVM failed Repair 3G/4G failed logger repair imei Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Old IMEI: Unknown New IMEI: 356845-05-xxxxxx-2 Creating NVM backup Reading NVM done! Firmware compiled date: Tue Jan 14 01:42:23 KST 2014 PDA version: I9505XXUFNA5 CSC version: I9505OXAFNA5 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-18-04-2014_14-41-49-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Found phone on COM18 Repairing NVM for GT-I9505 phone... Write IMEI failed logger unlock -------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Firmware compiled date: Tue Jan 14 01:42:23 KST 2014 PDA version: I9505XXUFNA5 CSC version: I9505OXAFNA5 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-18-04-2014_15-06-17-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Found phone on COM18 Repairing NVM for GT-I9505 phone... Phone unlocking failed |
04-18-2014, 14:29 | #18 (permalink) | |||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Hello. 1. As You can see from this Software log, modem part is damaged in your device: Quote:
At first, try to re-flash the device and check whether modem is correct (not Unknown) and only then (when phone's modem part will be correct) try to perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. 2. When phone's modem part will be correct, You need to connect the device correctly. Phone's info should be read fully and correctly. In your case, the phone is not connected correctly: Quote:
04-18-2014, 16:25 | #20 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Read written above 1.: Modem part is damaged in your device. At first, try to re-flash the device and check whether modem is correct (not Unknown) and only then (when phone's modem part will be correct) try to perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. |
06-09-2014, 03:15 | #22 (permalink) |
No Life Poster Join Date: Mar 2013
Member: 1900730 Status: Offline Thanks Meter: 188 | can't repair imei here read from Android /EFS Manager Code: Plataforma: Samsung Android Puerto seleccionado: COM9 Modelo seleccionado: GT-I9505 Reading info, please wait... Modelo del teléfono detectado: GT-I9505 Fecha de creación del firmware: Tue Jan 14 01:42:23 KST 2014 PDA version: I9505XXUFNA5 CSC version: I9505OXAFNA5 Versión del SW: I9505XXUFNA5 IMEI del teléfono: 35684---------- Phone SN: RV1D65S2E6D Android version: 4.4.2 (KOT49H) Code: ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM9 Modelo seleccionado: GT-I9505 Modo: Emergencia Write IMEI failed |
06-09-2014, 06:53 | #23 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Quote:
To connect GT-I9505, you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. | |
06-09-2014, 07:05 | #24 (permalink) | |
Member: 1900730 Status: Offline Thanks Meter: 188 | Quote:
and use this files Firmware I9505XXUFNA5_I9505OXAFNA5_I9505XXUFNA5_OXA_4.4.2.o ct root Root_GT-I9505_new.oct and unlock and repair GT-I9505_for_Unlock_and_IMEI_repair.oct same error | |
06-09-2014, 07:12 | #25 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | What is the same error? Post here full Software log with Repair IMEI procedure. In the Software log, which You have posted above, You have not connected the device correctly. |
06-09-2014, 07:13 | #26 (permalink) |
Freak Poster Join Date: Sep 2012 Location: in-ur-heart
Member: 1814389 Status: Offline Sonork: 100.1621147 Thanks Meter: 30 | 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. |
06-09-2014, 15:57 | #27 (permalink) | |
Download 08-06-2014_20-59-13.logx from Sendspace.com - send big files the easy way | |
