01-26-2014, 12:46 | #1 (permalink) |
Insane Poster Join Date: Aug 2013 Location: Palestine
Member: 2002321 Status: Offline Thanks Meter: 2 | I9505 network problem!!! i am facing problem with i9505 (the mobile is unlocked) ...before i was able to connect to the both networks in my country but now i can do for only one !! any ideas ??? Welcome to Octoplus/Octopus Box Samsung software version 1.4.6 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: GT-I9505 Reading info, please wait... Detected phone model: GT-I9505 Firmware compiled date: Sun Oct 13 18:54:31 KST 2013 PDA version: I9505XXUEMJ5 CSC version: I9505OJVEMJ5 SW version: I9505XXUEMJ5 Phone IMEI: 357138050985529 Phone SN: RF1D478W82J Android version: 4.3 (JSS15J) |
01-26-2014, 12:54 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please try make "Repair NVM" and check, whether network is available (active). If this will not help - try to perform "Unlock" operation and post here the result. |
01-26-2014, 13:04 | #3 (permalink) |
Member: 2002321 Status: Offline Thanks Meter: 2 | Welcome to Octoplus/Octopus Box Samsung software version 1.4.6 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Creating NVM backup Reading NVM done! Repairing NVM for GT-I9505 phone... Writing NVM failed NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Reading security failed Phone unlocking failed |
01-26-2014, 14:24 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As You can see from this Software log, your device is not connected correctly: Quote:
To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. When phone's info will be read correctly, to unlock the device do the next: 1. Write firmware "For_Unlock_and_IMEI_Repair_GT-I9505.oct" fom the Support Area from the folder "Samsung/FOR UNLOCK AND REPAIR/". 2. Root the device, as this is written in Software manual again. 3. Make "Unlock". 4. Post here full Software log with all of your actions. | |
01-27-2014, 08:35 | #5 (permalink) |
Member: 2002321 Status: Offline Thanks Meter: 2 | i am realy very thankful for your fast reply!!! dear octopus i am facing problem with *#9090# menu...when i dial the combination, the menu will pop up but with empty page !!! i am on 4.3 android !!! |
01-27-2014, 09:27 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please try to write firmware "I9505XXUEMI8_I9505OXAEMI8_I9505XXUEMI8_OXA_Androi d_4.3.oct" from the Support Area and then perform steps 1-14 to connect the device once again. |
