12-31-2013, 07:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2011 Location: mexico
Member: 1681847 Status: Offline Thanks Meter: 103 | I9505 no signal bars and imei is OK Repaired imei OK Repair EFS OK Rapair network OK Unlock OK But still no signal. What could be the problem |
12-31-2013, 07:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please try to do the next: 1. Re-flash the device. 2. Perform "Unlock" operation. 3. Make "Repair NVM" 4. Make "Repair IMEI". 5. Try to select network manually, try to use different SIM cards. To make Repair IMEI You should perform the next steps: a. Root your device manually. b. Make "Repair Security". c. Connect powered-on phone to PC via Samsung Micro UART cable. d. Enter correct IMEI. e. Click "IMEI fix" button. f. Follow software instructions (prompts). If after of these actions (1-5) network still will be disabled (inactive), check phone's HW. |
