07-14-2014, 10:34 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | i9505 phone not read full info [Solved] ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM70 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: All Setting Done phone not read full info Last edited by Octopus box; 07-15-2014 at 12:35. |
07-14-2014, 10:38 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Make Factory data reset, perform steps 1-13 once again and try to read info. Try to select another COM port manually. |
07-14-2014, 10:56 | #3 (permalink) | |
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
Platform: Samsung Android Selected port: COM70 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Repairing 3G/4G... Writing NVM failed Repair 3G/4G failed same problem | |
07-15-2014, 11:24 | #4 (permalink) |
Member: 1418524 Status: Offline Thanks Meter: 186 | Platform: Samsung Android Selected port: COM70 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM76 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 13 2014 Firmware released time: 21:32:10 Phone IMEI: 300000000000000 SW version: M9615A-CEFWTAZM-4.0.17135 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM76 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 13 2014 Firmware released time: 21:32:10 Phone IMEI: 35000000000000000 SW version: M9615A-CEFWTAZM-4.0.17135 Repairing 3G/4G... 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) All Done |
The Following User Says Thank You to gsaara For This Useful Post: |
