12-04-2013, 15:04 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Rio de Janeiro - Brasil
Member: 797068 Status: Offline Thanks Meter: 75 | i9505 unlock ok, but not network [Solved] Bemvindo na Octoplus/Octopus Box Samsung software versão 1.4.0 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM55 Modelo seleccionado: GT-I9505 Modo: Normal Modelo do telefone: GT-I9505 Data de criação do firmware: Mar 28 2013 Tiempo de criação do firmware: 09:00:00 Data de saída do firmware: Apr 12 2013 Tiempo de saída do firmware: 18:16:13 IMEI do telefone: 357441-05-034941-9 Versão do SW: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM55 Modelo seleccionado: GT-I9505 Modo: Normal Modelo do telefone: GT-I9505 Data de criação do firmware: Mar 28 2013 Tiempo de criação do firmware: 09:00:00 Data de saída do firmware: Apr 12 2013 Tiempo de saída do firmware: 18:16:13 IMEI do telefone: 357441-05-034941-9 Versão do SW: M9615A-CEFWTAZM-4.0.17062 Liberando o telefone... O telefone foi liberado com êxito To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM55 Modelo seleccionado: GT-I9505 Modo: Normal Modelo do telefone: GT-I9505 Data de criação do firmware: Mar 28 2013 Tiempo de criação do firmware: 09:00:00 Data de saída do firmware: Apr 12 2013 Tiempo de saída do firmware: 18:16:13 Versão do SW: M9615A-CEFWTAZM-4.0.17062 IMEI antigo: 357441-05-034941-9 Novo IMEI: 357441-05-034914-6 Reparando o NVM para o telefone GT-I9505... A reparação de NVM foi terminada com êxito New IMEI successfully written. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM55 Modelo seleccionado: GT-I9505 Modo: Normal Modelo do telefone: GT-I9505 Data de criação do firmware: Mar 28 2013 Tiempo de criação do firmware: 09:00:00 Data de saída do firmware: Apr 12 2013 Tiempo de saída do firmware: 18:16:13 IMEI do telefone: 357441-05-034941-9 Versão do SW: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Last edited by Octopus box; 12-04-2013 at 17:37. |
12-04-2013, 16:16 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Hello. To do Repair IMEI, You need carefully perform all the steps from Software manual. Do these steps and post here full Software log with all of them. Repair IMEI 1. Root your phone manualy. 2. Make Repair Security. 3. Connect powered-on phone to PC via Samsung Micro UART cable. 4. Enter correct IMEI. 5. Click "IMEI fix" button. 6. Follow software instructions (prompts). |
12-04-2013, 16:57 | #3 (permalink) | |
Member: 797068 Status: Offline Thanks Meter: 75 | Quote:
Bemvindo na Octoplus/Octopus Box Samsung software versão 1.4.0 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Porto seleccionado: COM55 Modelo seleccionado: GT-I9505 Modo: Normal Modelo do telefone: GT-I9505 Data de criação do firmware: Mar 28 2013 Tiempo de criação do firmware: 09:00:00 Data de saída do firmware: Apr 12 2013 Tiempo de saída do firmware: 18:16:13 IMEI do telefone: 357441-05-034941-9 Versão do SW: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM55 Modelo seleccionado: GT-I9505 Modelo do telefone detectado: GT-I9505 Data de criação do firmware: Fri Apr 12 17:10:46 KST 2013 Phone SN: R21D5376LNK Android version: 4.2.2 (JDQ39) Writing Security, please wait... O telefone se reiniciará agora ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM55 Modelo seleccionado: GT-I9505 Modo: Normal Modelo do telefone: GT-I9505 Data de criação do firmware: Mar 28 2013 Tiempo de criação do firmware: 09:00:00 Data de saída do firmware: Apr 12 2013 Tiempo de saída do firmware: 18:16:13 Versão do SW: M9615A-CEFWTAZM-4.0.17062 IMEI antigo: 357441-05-034941-9 Novo IMEI: 357441-05-034914-6 New IMEI successfully written. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM55 Modelo seleccionado: GT-I9505 Modo: Normal Modelo do telefone: GT-I9505 Data de criação do firmware: Mar 28 2013 Tiempo de criação do firmware: 09:00:00 Data de saída do firmware: Apr 12 2013 Tiempo de saída do firmware: 18:16:13 IMEI do telefone: 357441-05-034914-6 Versão do SW: M9615A-CEFWTAZM-4.0.17062 Write imei , but not network!!! | |
