07-04-2014, 18:42 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Hong Kong Age: 45
Member: 229358 Status: Offline Thanks Meter: 12 | i9505 Write IMEI failed , what's wrong ?? Code: Welcome to Octoplus/Octopus Box Samsung software version 1.6.0 ----------------------------------------------------------------------------------- To connect SGH-I337M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9506 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9505 Mode: Emergency Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM92 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: - Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM92 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: - Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM92 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: - Firmware released time: SW version: Old IMEI: Unknown New IMEI: 354898-32-898982-6 Creating NVM backup NVM reading process canceled IMEI write canceled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM92 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: - Firmware released time: SW version: Old IMEI: Unknown New IMEI: 357377-05-983987-9 Creating NVM backup Reading NVM done! Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM92 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: - Firmware released time: SW version: Old IMEI: Unknown New IMEI: 357377-05-983987-9 Creating NVM backup Reading NVM done! Firmware compiled date: Sat Feb 22 15:07:34 KST 2014 PDA version: I9505ZHUFNB3 CSC version: I9505ZZHFNB3 SW version: I9505ZHUFNB3 Phone IMEI: 357197056203246 Phone SN: RF1D53KRMGV Android version: 4.4.2 (KOT49H) Cheking Root Can't root Android version 4.4.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM92 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: - Firmware released time: SW version: Old IMEI: Unknown New IMEI: 357377-05-983987-9 Creating NVM backup Reading NVM done! ADB server killed. Firmware compiled date: Sat Feb 22 15:07:34 KST 2014 PDA version: I9505ZHUFNB3 CSC version: I9505ZZHFNB3 SW version: I9505ZHUFNB3 Phone IMEI: 357197056203246 Phone SN: RF1D53KRMGV Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP \Security-GT-I9505-357197056203246-05-07-2014_01-31-01-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 22 2014 Firmware released time: 15:52:50 SW version: M9615A-CEFWTAZM-4.0.17135 Found phone on COM93 Repairing NVM for GT-I9505 phone... Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM93 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 22 2014 Firmware released time: 15:52:50 SW version: M9615A-CEFWTAZM-4.0.17135 Old IMEI: 004400-15-202000-0 New IMEI: 357377-05-983987-9 Creating NVM backup Reading NVM done! Firmware compiled date: Sat Feb 22 15:07:34 KST 2014 PDA version: I9505ZHUFNB3 CSC version: I9505ZZHFNB3 SW version: I9505ZHUFNB3 Phone IMEI: Unknown Phone SN: RF1D53KRMGV Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP \Security-GT-I9505-05-07-2014_01-36-12-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 22 2014 Firmware released time: 15:52:50 SW version: M9615A-CEFWTAZM-4.0.17135 Found phone on COM93 Repairing NVM for GT-I9505 phone... Write IMEI failed |
07-04-2014, 18:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please do the next: 1. Write firmware "I9505XXUFNA5_I9505OXAFNA5_I9505XXUFNA5_OXA_4. 4.2" from Support Area. 2. Write modem file "I9505XXUFNA1-MODEM" and GT-I9505_for_Unlock_and_IMEI_repair.oct". 3. Root the device. 4. Reboot the phone. 5. Connect powered on phone via Micro USB cable directly to PC (don't use USB hubs etc.). 6. Enter correct IMEI. 7. Click "IMEI fix" button. 8. Follow software instructions (prompts). Last edited by Octopus box; 07-05-2014 at 07:56. |
07-05-2014, 11:06 | #3 (permalink) |
Freak Poster Join Date: May 2014 Location: Turkey/İzmir
Member: 2187028 Status: Offline Thanks Meter: 21 | Hİ Octopus Team i9505 imei repair error Root_GT-I9505_new.oct ----------------------------------------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM103 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM103 Phone connection failed No diagnostic ports found! Connecting to phone on COM3 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9505 Mode: Emergency Write IMEI failed |
07-05-2014, 11:10 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please perform speps 1-8 mentioned above. Also, to connect GT-I9506, You have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. |
07-05-2014, 11:16 | #5 (permalink) |
Member: 2187028 Status: Offline Thanks Meter: 21 | ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM105 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM106 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Nov 01 2013 Firmware compiled time: 11:00:00 Firmware released date: Nov 21 2013 Firmware released time: 16:17:16 SW version: M9615A-CEFWTAZM-4.0.17125 Old IMEI: 359921-05-724670-8 New IMEI: 354847-04-280382-1 Creating NVM backup Reading NVM done! Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed |
07-05-2014, 11:35 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
07-05-2014, 12:00 | #8 (permalink) |
Member: 2187028 Status: Offline Thanks Meter: 21 | USB debug open. Platform: Samsung Android Selected port: COM105 Selected model: GT-I9506 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM106 Mode: Emergency |
07-07-2014, 06:59 | #10 (permalink) |
Major Poster Join Date: Jun 2014
Member: 2214386 Status: Offline Thanks Meter: 2 | this is the problem box only connects when its on Android/EFS manager see below Platform: Samsung Android Selected port: COM65 Selected model: GT-I9505 Reading info, please wait... Detected phone model: GT-I9505 Firmware compiled date: Thu Jul 11 19:56:37 KST 2013 PDA version: I9505XXUBMGA CSC version: I9505OXXBMG3 SW version: Unknown Phone IMEI: Unknown Phone SN: RF1D478W82J Android version: 4.2.2 (JDQ39) Then it will not connect with Repair Imei or Main Platform: Samsung Android Selected port: COM65 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM65 Mode: Emergency |
07-07-2014, 07:06 | #11 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform the "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. | |
07-07-2014, 07:42 | #13 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Read what I have written above: Quote:
07-15-2014, 06:45 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please do the next: 1. Write firmware "I9505XXUFNA5_I9505OXAFNA5_I9505XXUFNA5_OXA_4. 4.2" from Support Area. 2. Write modem file "I9505XXUFNA1-MODEM" and GT-I9505_for_Unlock_and_IMEI_repair.oct". 3. Root the device. 4. Reboot the phone. 5. Connect powered on phone via Micro USB cable directly to PC (don't use USB hubs etc.). 6. Enter correct IMEI. 7. Click "IMEI fix" button. 8. Follow software instructions (prompts). 9. Post here full Software log with all of these actions (or, if You can't post log, upload it somewhere and send us link to PM). |
