02-25-2014, 13:51 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Marruecos Age: 44
Member: 39250 Status: Offline Thanks Meter: 64 | I9506 not good signal network i have 2 phone i9506 new with this problem; signal network is not good with other phone signal is 100% with this some time is 100% sometime 50% some time no signal is problem hard or soft ?? THX |
02-25-2014, 14:07 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. This can be Software problem and, also, this can be HW problem. Try to re-flash the device with another firmware, try to make Repair NVN. Try to read NVM from the device in which signal is 100% and write it into device with weak signal. Don't forget to make all backups from the device before (NVM, Security and EFS). |
02-25-2014, 15:34 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to read NVM from the device in which signal is 100% and write it into device with weak signal. Also this can be HW problem. |
02-25-2014, 17:55 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As I have said above, good NVM is inside of Software - "Repair NVM" button. Ask other users, maybe they have NVM for this device. Also check phone's HW. |
06-13-2014, 22:06 | #12 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Morocco
Member: 136492 Status: Offline Thanks Meter: 289 | don't west your time Brother there is no solution for this problem. i've trayed before with I9500 & I9506 but without success. But i'm sure the problem happen when you direct unlock them (dont mater wish tool you've used) |
06-14-2014, 08:13 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to make Repair NVM and re-flash the phone. Also, if You have the same device with strong signal, try to write NVM backup from this phone. |
