02-07-2015, 14:31 | #1 (permalink) |
Freak Poster Join Date: Oct 2010 Location: india
Member: 1417201 Status: Offline Sonork: 100.1626868 Thanks Meter: 32 | ii9305 EFS INVALID ARGUMENT I ALREADY TRY REPAIR EFS HERE IS LOG BUT PROBLEM REMANING Welcome to Octoplus/Octopus Box Samsung software version 1.8.3 ----------------------------------------------------------------------------------- To connect GT-S5830 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Press Home button. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9305 To put GT-I9305 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... EFS Repair successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9305 To put GT-I9305 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... EFS Repair successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9305 Mode: Emergency NVM can’t be repaired for GT-I9305 phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9305 Operation was canceled Reading EFS was canceled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9305 To put GT-I9305 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... EFS Repair successfully |
02-07-2015, 14:44 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Most likely, this is HW issue. Try also to read out EFS backup from the same working device and write it into your phone. Unfortunately, currently we have no EFS backups for this device. Try to re-flash the phone. If the problem is the same, most likely, this is HW problem (problem with phone's flash chip). |
02-07-2015, 15:25 | #7 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Kuwait
Member: 735013 Status: Offline Thanks Meter: 74 | Sorry I cant upload it for you. Try to google it I9305_IMEI_Repair I9305XXALI5_I9305VD2ALI4_I9305BUALI6_CSC I9305XXALI5_I9305VD2ALI4_I9305BUALI6_PDA I9305XXALI5_I9305VD2ALI4_I9305BUALI6_PHONE |
02-09-2015, 06:03 | #8 (permalink) | |
Member: 1417201 Status: Offline Sonork: 100.1626868 Thanks Meter: 32 | Quote:
02-09-2015, 08:08 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, read out phone's info via ADB (turn on USB Debugging Mode in the phone and press "Read info" button at "Android / EFS manager" tab in the Software) and post here full Software log with this info. |
02-09-2015, 08:57 | #10 (permalink) | |
----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Press Home button. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9305 Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9305 Firmware compiled date: Thu Jan 2 18:17:10 KST 2014 PDA version: I9305ZHUCNA1 CSC version: I9305TGYCNA1 SW version: I9305ZHUCMK1 Phone IMEI: Unknown Phone SN: RF1CC4BN6SZ Android version: 4.3 (JSS15J) Last edited by salimmalikgolde; 02-09-2015 at 09:03. | |
02-09-2015, 11:52 | #14 (permalink) | |
Selected port: COM42 Selected model: GT-I9305 To put GT-I9305 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... EFS Repair successfully | |
02-09-2015, 11:56 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Ok, now configure the phone correctly. To connect GT-I9305, perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Press Home button. 13. Go to dial window. 14. Press "Read Info" in software. When info will be read out correctly, make Repar IMEI. |
