06-12-2014, 01:58 | #1 (permalink) |
Freak Poster Join Date: Dec 2012 Location: The North
Member: 1861077 Status: Offline Thanks Meter: 89 | Imei certi: Failed .. Network: Blocked ----------------------------------------------------------------------------------- To connect SM-N900W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. = Platform: Samsung Android Selected port: COM3138 Selected model: SM-N900W8 Mode: Normal Phone model: SM-N900W8 Firmware compiled date: Feb 05 2014 Firmware compiled time: 05:00:00 Firmware released date: Feb 21 2014 Firmware released time: 19:05:52 Phone IMEI: 357507-05-005289-6 SW version: M8974A-AAAANAZM-2.0.10028 Unlocking phone... Creating NVM backup Reading NVM done! Connecting to ADB, please waite... Firmware compiled date: Thu Feb 27 17:12:49 KST 2014 PDA version: N900W8VLUCNB7 CSC version: N900W8OYACNB7 SW version: N900W8VLUCNB7 Phone IMEI: 357507050052896 Phone SN: RV8DC03R2PP Android version: 4.4.2 (KOT49H) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900W8-357507050052896-11-06-2014_20-46- 17-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... Phone found. Writing new IMEI. Please wait... Please connect phone to USB cable and press OK button. Serching phone... Firmware compiled date: Feb 05 2014 Firmware compiled time: 05:00:00 Firmware released date: Feb 21 2014 Firmware released time: 19:05:52 Phone IMEI: 357507-05-000001-0 SW version: M8974A-AAAANAZM-2.0.10028 Found phone on COM3138 Repairing NVM for SM-N900W8 phone... Repairing 3G/4G... 3G/4G repair successfully Phone is successfully unlocked Last edited by alifauad79; 06-12-2014 at 02:05. |
06-12-2014, 07:09 | #3 (permalink) |
Member: 1861077 Status: Offline Thanks Meter: 89 | I just flashed a new ROM and still not good.. The only thing left is I saw the option PHONE EFS CLEAR option in ODIN but don't know is it advisable to do.. can it be repairable with OCTOPUS if I happen to clear the EFS.. Developers/Octopus Team still waiting for any solution.. Thanks in advance. |
06-12-2014, 07:10 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Try to write Security backup "Security-SM-N900W8-357507050052896-11-06-2014_20-46-17-.asec" back into the phone and then write another service IMEI. |
06-12-2014, 07:15 | #5 (permalink) |
Member: 1861077 Status: Offline Thanks Meter: 89 | It is not writing the security issue.. or you think IMEI CERT: Failed is Security issue, because the initial security while I was performing this step was never saved because when it comes to connecting to UART Cable my phone kept saying searching, after cancelling the process, and did some more research I saw your comment where you said that we can connect another box and use UART cable through that box. So, I don't know if I have original security saved or not. I hope you can shed some light how to fix IMER CERT: Failed.. Network: Blocked as shown in image. |
06-12-2014, 07:25 | #6 (permalink) |
Member: 1861077 Status: Offline Thanks Meter: 89 | I have written the backup security as you mentioned and I am still getting the same IMEI CERT: Failed I have uploaded the Text file for all the operations I have done |
06-12-2014, 07:36 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Most likely, the problem is with phone's EFS and Security. Unfortunately, Repair/Reset EFS is currently not supported for this device. We will try to add Repair/Reset EFS operation for this device in one of the future Software updates. |
06-12-2014, 21:33 | #12 (permalink) | |
Member: 1861077 Status: Offline Thanks Meter: 89 | Quote:
Lesson learnt, before start any NOTE III Make a backup of NVM, Security and EFS before started messing with UNLOCK or IMEI Repair. | |
06-12-2014, 21:53 | #13 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2127241 Status: Offline Thanks Meter: 7 | i have good efs and nvm. i had same problem and mine was a higher version firmware 4.4.2 baseband ne6. nobody could help me so i messed around and i repaired the imei now getting voLTE with the new update and all. |
06-12-2014, 22:36 | #14 (permalink) |
Member: 1861077 Status: Offline Thanks Meter: 89 | Mine is NB7, I have asked the support if we can use the EFS or NVM from other phone, and all I got the reply all you need is RESET EFS which is not supported by OCTOPUS.. So I don't know if you have any experience in the past that you know it can be fixed by borrowing the EFS from other phone? Any help will be appreciated |
