05-23-2017, 14:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | imei null ----------------------------------------------------------------------------------- To connect SM-G530H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G530H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G530H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-P6800 Detected phone model: GT-P6800 Firmware compiled date: Thu Nov 8 17:38:57 KST 2012 PDA version: P6800JPLPA CSC version: P6800OJPLP7 SW version: unknown Android version: 4.0.4 (IMM76D) Sales code: XSG Country: UAE HW platform: exynos4 HW Chip: unknown HW Modem: unknown Codename: GT-P6800 Checking Root: Phone is Rooted. Repairing network. Please wait, this can take some time... Unknown security, please write firmware from support Repairing network failed. Write IMEI failed Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-P6800 Searching for a phone. Please wait... Phone found. Detected phone model: GT-P6800 Firmware compiled date: Thu Nov 8 17:38:57 KST 2012 PDA version: P6800JPLPA CSC version: P6800OJPLP7 SW version: unknown Android version: 4.0.4 (IMM76D) Sales code: XSG Country: UAE HW platform: exynos4 HW Chip: unknown HW Modem: unknown Codename: GT-P6800 SN repaired successfully. Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-P6800 Detected phone model: GT-P6800 Firmware compiled date: Thu Nov 8 17:38:57 KST 2012 PDA version: P6800JPLPA CSC version: P6800OJPLP7 SW version: unknown Android version: 4.0.4 (IMM76D) Sales code: XSG Country: UAE HW platform: exynos4 HW Chip: unknown HW Modem: unknown Codename: GT-P6800 Checking Root: Phone is Rooted. Repairing network. Please wait, this can take some time... Unknown security, please write firmware from support Repairing network failed. Write IMEI failed Performed by 2.5.4 Software version. |
05-23-2017, 14:43 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Hello. As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair IMEI"/"Repair network" operation. It is not possible to repair IMEI, if phone's modem part is damaged. | |
