02-29-2016, 15:48 | #1 (permalink) |
Crazy Poster Join Date: Mar 2008 Location: Colombia, Valle, Cali Age: 37
Member: 724480 Status: Offline Sonork: maurodevil Thanks Meter: 8 | imei repair n900v |
02-29-2016, 16:56 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What was initial problem of the phone? What was the reason to repair NVM? Please post here full Software log of all operations, which You've performed with the phone. |
03-01-2016, 15:46 | #3 (permalink) | |
Member: 724480 Status: Offline Sonork: maurodevil Thanks Meter: 8 | Quote:
the phone came to use any operator and after applying unlocking the phone kept saying the sim card was not verizon proceeded to repair the NVM and the phone I do not get over that sign but stopped taking data and the signal appears with a x | |
03-01-2016, 15:56 | #4 (permalink) |
Member: 724480 Status: Offline Sonork: maurodevil Thanks Meter: 8 | INFO : 22/02/2016 18:06:16 > To connect SM-N900V phone you have to perform the following steps: INFO : 22/02/2016 18:06:16 > 1. Disconnect USB cable from phone. INFO : 22/02/2016 18:06:16 > 2. Go to Menu->Settings->More->About Device. INFO : 22/02/2016 18:06:16 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 22/02/2016 18:06:16 > 4. Go to Menu->Settings->More->Developer options. INFO : 22/02/2016 18:06:16 > 5. Turn on "USB Debugging" option. INFO : 22/02/2016 18:06:16 > 6. Go to dial window. INFO : 22/02/2016 18:06:16 > 7. Enter "*#0808#" number. INFO : 22/02/2016 18:06:16 > 8. Select "DM+Modem+ADB". INFO : 22/02/2016 18:06:16 > 9. Press Home button. INFO : 22/02/2016 18:06:16 > 10. Go to dial window. INFO : 22/02/2016 18:06:16 > 11. Enter "##366633#" number. INFO : 22/02/2016 18:06:16 > 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. INFO : 22/02/2016 18:06:16 > 13. Restart phone. INFO : 22/02/2016 18:06:16 > 14. Press "Read Info" in software. INFO : 22/02/2016 18:09:04 > ----------------------------------------------------------------------------------- INFO : 22/02/2016 18:09:06 > Platform: Samsung Android INFO : 22/02/2016 18:09:06 > Selected port: COM26 INFO : 22/02/2016 18:09:06 > Selected model: SM-N900V INFO : 22/02/2016 18:09:06 > Reading info... INFO : 22/02/2016 18:09:06 > Mode: Normal INFO : 22/02/2016 18:09:06 > Firmware compiled date: Feb 06 2015 INFO : 22/02/2016 18:09:06 > Firmware compiled time: 02:00:00 INFO : 22/02/2016 18:09:06 > Firmware released date: Mar 6 2015 INFO : 22/02/2016 18:09:06 > Firmware released time: 19:18:59 INFO : 22/02/2016 18:09:07 > SW Version: MPSS.DI.2.0.c1-00111-M8974AAAAANAZM-1 ERROR : 22/02/2016 18:09:08 > Can't kill external ADB references. Please, close all programs that use ADB server. WARN : 22/02/2016 18:09:09 > Please, press "OK" button on the phone to allow USB debugging.. INFO : 22/02/2016 18:09:12 > Detected phone model: SM-N900V INFO : 22/02/2016 18:09:12 > Firmware compiled date: Thu Mar 12 16:35:56 KST 2015 INFO : 22/02/2016 18:09:13 > PDA version: N900VVRUEOB6 INFO : 22/02/2016 18:09:13 > CSC version: N900VVZWEOB6 INFO : 22/02/2016 18:09:14 > SW version: N900VVRUEOB6 INFO : 22/02/2016 18:09:16 > Phone SN: 00000000000 INFO : 22/02/2016 18:09:16 > Android version: 5.0 (LRX21V) INFO : 22/02/2016 18:09:16 > Checking Root: ERROR : 22/02/2016 18:09:17 > Phone is not Rooted. INFO : 22/02/2016 18:09:18 > Unlocking phone... WARN : 22/02/2016 18:09:19 > Phone will restart now. Please don't disconnect cable! INFO : 22/02/2016 18:09:19 > Phone is successfully unlocked WARN : 22/02/2016 18:09:19 > To finish the operation, please restart the phone via phone's menu. INFO : 22/02/2016 18:10:22 > Performed by 2.2.1 software version Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\22-02-2016_17-27-22.log" closed (22/02/2016 18:10:56). INFO : 22/02/2016 19:53:58 > Platform: Samsung Android INFO : 22/02/2016 19:53:58 > Selected port: COM32 INFO : 22/02/2016 19:53:58 > Selected model: SM-N900V INFO : 22/02/2016 19:53:58 > Reading info... INFO : 22/02/2016 19:53:58 > Mode: Normal INFO : 22/02/2016 19:53:58 > Firmware compiled date: Feb 06 2015 INFO : 22/02/2016 19:53:59 > Firmware compiled time: 02:00:00 INFO : 22/02/2016 19:53:59 > Firmware released date: Mar 6 2015 INFO : 22/02/2016 19:53:59 > Firmware released time: 19:18:59 INFO : 22/02/2016 19:53:59 > SW Version: MPSS.DI.2.0.c1-00111-M8974AAAAANAZM-1 INFO : 22/02/2016 19:54:00 > ADB server killed. WARN : 22/02/2016 19:54:00 > Please, press "OK" button on the phone to allow USB debugging.. INFO : 22/02/2016 19:54:05 > Detected phone model: SM-N900V INFO : 22/02/2016 19:54:05 > Firmware compiled date: Thu Mar 12 16:35:56 KST 2015 INFO : 22/02/2016 19:54:05 > PDA version: N900VVRUEOB6 INFO : 22/02/2016 19:54:06 > CSC version: N900VVZWEOB6 INFO : 22/02/2016 19:54:07 > SW version: N900VVRUEOB6 INFO : 22/02/2016 19:54:08 > Phone SN: 00000000000 INFO : 22/02/2016 19:54:08 > Android version: 5.0 (LRX21V) INFO : 22/02/2016 19:54:08 > Checking Root: ERROR : 22/02/2016 19:54:09 > Phone is not Rooted. INFO : 22/02/2016 19:54:10 > Unlocking phone... WARN : 22/02/2016 19:54:11 > Phone will restart now. Please don't disconnect cable! INFO : 22/02/2016 19:54:11 > Phone is successfully unlocked WARN : 22/02/2016 19:54:11 > To finish the operation, please restart the phone via phone's menu. INFO : 22/02/2016 19:54:24 > Performed by 2.2.1 software version INFO : 22/02/2016 20:00:34 > ----------------------------------------------------------------------------------- INFO : 22/02/2016 20:00:34 > Platform: Samsung Android INFO : 22/02/2016 20:00:34 > Selected port: COM32 INFO : 22/02/2016 20:00:34 > Selected model: SM-N900V INFO : 22/02/2016 20:00:34 > Mode: Normal INFO : 22/02/2016 20:00:34 > Phone model: SM-N900V INFO : 22/02/2016 20:00:34 > Firmware compiled date: Feb 06 2015 INFO : 22/02/2016 20:00:35 > Firmware compiled time: 02:00:00 INFO : 22/02/2016 20:00:35 > Firmware released date: Mar 6 2015 INFO : 22/02/2016 20:00:35 > Firmware released time: 19:18:59 INFO : 22/02/2016 20:00:35 > Phone IMEI: 990004-34-260786-2 INFO : 22/02/2016 20:00:35 > SW version: MPSS.DI.2.0.c1-00111-M8974AAAAANAZM-1 INFO : 22/02/2016 20:00:36 > Creating NVM backup INFO : 22/02/2016 20:03:08 > Reading NVM done! INFO : 22/02/2016 20:03:08 > Repairing NVM for SM-N900V phone... INFO : 22/02/2016 20:03:22 > NVM repair completed successfully WARN : 22/02/2016 20:03:22 > To finish the operation, please restart the phone via phone's menu. INFO : 22/02/2016 20:03:22 > Performed by 2.2.1 software version INFO : 23/02/2016 11:12:59 > Selected firmware file: n900vvrueof1_n900vvzweof1_vzw_android_5.0.oct WARN : 23/02/2016 11:13:04 > Please put the phone into Download Mode and connect USB cable. WARN : 23/02/2016 11:13:04 > To put SM-N900V into Download Mode, You have to perform the following steps: WARN : 23/02/2016 11:13:04 > 1. Reconnect the battery. WARN : 23/02/2016 11:13:04 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 23/02/2016 11:13:04 > 3. When phone turns on, press "Volume+" key. INFO : 23/02/2016 11:13:04 > Found phone on INFO : 23/02/2016 11:13:05 > Firmware write started. INFO : 23/02/2016 11:13:05 > Writing ABOOT section... INFO : 23/02/2016 11:13:07 > ABOOT section has been written successfully. INFO : 23/02/2016 11:13:07 > Writing SBL1 section... INFO : 23/02/2016 11:13:10 > SBL1 section has been written successfully. INFO : 23/02/2016 11:13:10 > Writing RPM section... INFO : 23/02/2016 11:13:12 > RPM section has been written successfully. INFO : 23/02/2016 11:13:12 > Writing TZ section... INFO : 23/02/2016 11:13:14 > TZ section has been written successfully. INFO : 23/02/2016 11:13:14 > Writing DBI section... INFO : 23/02/2016 11:13:16 > DBI section has been written successfully. INFO : 23/02/2016 11:13:16 > Writing APNHLOS section... INFO : 23/02/2016 11:13:19 > APNHLOS section has been written successfully. INFO : 23/02/2016 11:13:19 > Writing BOOT section... INFO : 23/02/2016 11:13:24 > BOOT section has been written successfully. INFO : 23/02/2016 11:13:24 > Writing RECOVERY section... INFO : 23/02/2016 11:13:28 > RECOVERY section has been written successfully. INFO : 23/02/2016 11:13:28 > Writing SYSTEM section... INFO : 23/02/2016 11:22:16 > SYSTEM section has been written successfully. INFO : 23/02/2016 11:22:16 > Writing CACHE section... INFO : 23/02/2016 11:22:35 > CACHE section has been written successfully. INFO : 23/02/2016 11:22:35 > Writing MODEM section... INFO : 23/02/2016 11:22:48 > MODEM section has been written successfully. INFO : 23/02/2016 11:22:49 > Firmware writing successfully completed. INFO : 23/02/2016 11:22:49 > Performed by 2.2.1 software version |
03-01-2016, 16:21 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You can restore the phone to it's initial condition by writing of NVM backup back into the phone. Please check status of IMEI Certi in *#0011# menu after You restore phone's NVM. |
06-26-2016, 21:58 | #6 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | Product support Help with SM-N900v I bought n900v from the local market only to find out that when I switch on straight fone ask for Phone activation.How may I reset this activation with my box |
06-28-2016, 08:35 | #9 (permalink) |
Member: 22284 Status: Offline Thanks Meter: 81 | ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N900V Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Performed by 2.2.9 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N900V Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.2.9 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N900V To put SM-N900V into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! |
06-28-2016, 10:37 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To configure SM-N900V phone for connection you need to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "##366633#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Connect the phone directly to PC. |
06-29-2016, 10:37 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please contact us to Skype, or Yahoo! Messenger, we will try to help You. Our contacts You can find in our profile. |
