10-09-2014, 18:38 | #17 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
10-14-2014, 13:04 | #21 (permalink) | |||
BR allumts | |||
10-21-2014, 02:04 | #25 (permalink) | |
Junior Member Join Date: May 2014
Member: 2182417 Status: Offline Thanks Meter: 0 | Quote:
10-21-2014, 11:25 | #26 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1799015 Status: Offline Thanks Meter: 0 | Possible Workaround Solution I'm going to try now!!! I'm going to use the old version of software to change to service IMEI and then connect the repaired imei phone to new software and backup QCN file. Then I can restore this to other phones? I agree, having hundred phones out there with same IMEI seems like bad idea. They could all be blocked at one time by same or all carriers via blacklist. What we need is easy way to edit the QCN file and change the IMEI in the QCN file. Or for someone to create program to create or edit existing cert files. I have never had problems with 3g/4g on Note 3 T-Mobile phones after changing to service imei!!! Is this how the S5 is going to be too? We need more options for editing QCN or Cert files..... asap to use this version of Octoplus. |
10-21-2014, 23:28 | #27 (permalink) | |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Quote:
Forget about editing cert files. Have you opened one up? The cert is VERY extensive and is ONLY for that IMEI. You can't just change the IMEI number and use the same CERT. It'll fail. If you repair enough note 3 phones you'll see what people are talking about with the network dropping with service IMEIs. The S5 doesn't have a service IMEI range AFAIK and I haven't seen network drop with them either after repairing the IMEI+CERT. | |
10-22-2014, 10:03 | #28 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | UPDATE ABOUT HOW TO UNLOCK/REPAIR WITH NEW METHOD, ONLY 3 STEPS and ALL DONE, NO MORE UART CABLE, ALL WITH MICROUSB, (Octopus Sw Vers. 1.7.1 or High): How to Unlock/Repair IMEI for SM-N900, and all N900x, like N900w8, N9005 itc... devices: 1) Root the phone 2) Perform Wipe Security procedure ("Repair Security/Wipe Security" button) 3) Write Certificate ("Write cert" button) Note: After performing steps 1-3, your device would be unlocked and IMEI changed to the one from Certificate file! Q: Where can I get Certificates' files? A: You can read out Certificates from supported Exynos-based devices (SM-N900, SM-N9000Q). Also, You can use original Samsung Certificates.(if have who sell you), or can Share HERE Read or Write CERT file, can see also in this Video, here link: https://www.youtube.com/watch?featur...&v=DVxRxGZ2jbg Q: Can Read Out CERT file from N900/N900Q and Write in any Samsung device N900X? A: Yes You can Write CERT file from Any N900/N900Q Exinos based-device on any Qualcomm N900X, like N9005,itc..., Sw Octopus Ceck automatic compatibility and Write it. If this guide is helpful for you, Press only Thanks Button ________ BR allumts |
The Following 5 Users Say Thank You to allumts For This Useful Post: |
10-24-2014, 21:54 | #29 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2228558 Status: Offline Thanks Meter: 4 | a question I have do I need to make just a back up of the QCN file would that be enough to recover phone if something goes wrong or is it neccessary to make back up of the NVM and EFS to me would be better to make sure we can read and write the 3 files metion above before performing any of these task (wiping security and writing a certificate) |
10-25-2014, 00:53 | #30 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Venezuela
Member: 594580 Status: Offline Thanks Meter: 157 | I have a question.. Q - I have a locked G900 phone, then I make all backups (Cert, Qnc, EFS, etc) then I make Wipe EFS procedure then write back Cert file, It will be unlocked or not? Simlock config is inside Cert file and IMEI also or only IMEI is inside? A- ? Hello supporters. |
