08-23-2015, 22:00 | #123 (permalink) |
Freak Poster Join Date: Mar 2012
Member: 1735558 Status: Offline Thanks Meter: 6 | That i want to say as all you know ımei number must be 15 digits and the last digit creating automuticly. That file last digit must be 9 but after i write cert digit will be 0. How is that possible ? ? |
08-24-2015, 15:18 | #124 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
CERT file is only other thing of write manual numbers...Cert file is CRYPTED by Samsung and cannot be Edited. goes used As Is how is done stop, if edit this can get in the trush. So repeat for second time, if you have CERT file use Write Cert button in sw not must need of use any Manual numbers just read the above Steps.. Also for Wipe Security/EFS there Button in Sw. But please First of Touch one I9500, DO ALL BKP of SECURITY AREA, EFS, QCN, NV, itc... becouse if do any mistake, (easy seen not has understand difference enter CERT file and MANUAL numbers), and in case algo goes Wrong you can repair/restore to original state...if not do It can get you phone in the Trush...any solution for restore I9500 w/o FULL BKP. Read Sticky Thread about I9500 phones. BR allumts | |
03-25-2016, 02:52 | #125 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2546979 Status: Offline Thanks Meter: 0 | Need help with cert efs wipe etc Hi I am new to octoplus and all of this. Can you help me install octoplus box correctly. I get a message card not found when using. Also I was reading your info about wiping efs first and then write. But what you said about doing before wiping efs, was confusing to me. By the way i am working with a sm-g928 phone. Thanks |
03-25-2016, 10:19 | #126 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | For this request, are 2 way, or Open you own Thread and explain what problem you have in clear details, or i can redirect to does this Full service by T.Viewer. About Wipe EFS itc...NOT TOUCH NOTHING, no need any WIPE EFS for these model, just Press "MSL reset" Button, and Write Cert nothing more, off course Roteed phone and Setted how Sw prompt. IMPORTANT: DO ALL BACKUP of EFS, SECURITY AREA, ITC...First of ANY operaction, also the more easy, Press ALWAYS "HELP" button in Sw here is Explained RIGHT procedure for Each Model. BR allumts |
03-25-2016, 10:43 | #127 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | FOR ALL USERS: How can see this thread is been open from long time and Many Things are Changed, ESPECIALLY in Wipe Security/EFS button. NOT USE this Button for Many New Model, like S6/S6Edge and many Others, there's one easy Button called "MSL RESET", Just press this first of write Cert and can Write Cert w/o issue, NOT WIPE EFS, and First of Any Operaction, also the More easy, DO ALL BKP of EFS, SECURITY AREA, QCN, (where is allowed), itc.. ONLY in this mode can restore Back you phone if happen algo in Easy mode!!! IMPORTANT: First of Touch any Button in Sw "MAKE SURE" of to have Read Carefully what explained by "HELP" Button in Sw, for Each Model, USE ALWAYS, then Set Phone Exactly how SW PROMPT, not do it and you will be other one in the list of Users with Damaged Phone in YOU Handles!!! BR allumts |
The Following 2 Users Say Thank You to allumts For This Useful Post: |
04-25-2017, 16:30 | #134 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2710153 Status: Offline Thanks Meter: 0 | I have lost my IMEI and serial number, I have another phone but I don't find option read cert there is only write cert on samsung tool pro latest version. My phone A500W, how I can fix it? do i need to install firmware through ODIN or Z3X? Thanks |
04-26-2017, 15:50 | #135 (permalink) | |
Here are in OCTOPUS Section not Z3x section, loock carefully where post. | |
