11-23-2016, 12:48 | #1 (permalink) |
Freak Poster Join Date: Jan 2013 Location: RUSSIA
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | J100H LOGO Stuck dead after flash by OctopusBox [Solved] Welcome to Octoplus/Octopus Box Samsung software version 2.4.4 ----------------------------------------------------------------------------------- To connect SCL24 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. Selected firmware file: j100hxxu0aoj1_j100hojv0aoj1_xfa_android_ 4.4.4.oct Please put the phone into Download Mode and connect USB cable. To put SM-J100H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing SBOOT section... SBOOT section has been written successfully. Writing SBOOT2 section... SBOOT2 section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing system section... system section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing WDSP section... WDSP section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.4.4 Software version. ----------------------------------------------------------------------------------- The phone came to the shop without any other interventions, was stuck on Samsung LOGO. After flash the handset is dead! I tryed with full battery other baterry, Download mode JIG ... Nothing. Last edited by Octopus box; 11-23-2016 at 14:20. |
11-23-2016, 13:49 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Try to fully charge phone battery, then check whether phone powers on, or whether it enters Download Mode. |
11-23-2016, 14:16 | #8 (permalink) |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | problem solved.... [ dismantled the phone and cleanning the motherboard with ultrasonic bath.] thank you all for the fast reply , i request this thread closed. |
