10-24-2015, 05:05 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | j100y after unlock no network Code: Welcome to Octoplus/Octopus Box Samsung software version 2.0.8 ----------------------------------------------------------------------------------- To connect SM-G925I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: sm-j100y_dxu0aoc1_root.oct Please put the phone into Download Mode and connect USB cable. To put SM-J100Y into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" +"Power"+''Home" keys. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-J100Y Detected phone model: SM-J100Y Firmware compiled date: Wed Apr 1 14:44:34 KST 2015 PDA version: J100YDXU0AOD1 CSC version: J100YSKY0AOD1 SW version: J100YDXU0AOC3 Phone IMEI: 358926061221473 Phone SN: R28G84ERMXR Android version: 4.4.4 (KTU84P) Cheking Root Phone is Rooted Deactivating MSL... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NV-SM-J100Y-358926061221473 file MSL deactivate successfully Unlocking phone... Please insert card into phone, if phone is locked, then type 00000000 Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. |
10-24-2015, 05:59 | #3 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
I can not search it when I go to network mode I can see like this non of the network mode selected When I select network mode Network mode show graydout After unlock it damaged network file I think what to do now ? | |
10-26-2015, 10:51 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please upload *.log and *.logx files of "Unlock" operation and post here download link. We will check where can be the problem. |
