08-06-2016, 09:12 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | J200F hang on logo Welcome to Octoplus/Octopus Box Samsung software version 2.3.2 ----------------------------------------------------------------------------------- To connect SCL24 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J200F Searching for a phone. Please wait... Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM16 Phone connection failed No diagnostic ports found! Connecting to phone on COM8 Phone connection failed Performed by 2.3.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J200F To put SM-J200F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Performed by 2.3.2 software version Selected firmware file: J200FXXU1AOI6_J200FOJV1AOI6 _J200FXXU1AOI5_HOME.oct Please put the phone into Download Mode and connect USB cable. To put SM-J200F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.3.2 software version |
The Following User Says Thank You to Yasir Ali For This Useful Post: |
08-06-2016, 11:59 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Try to make Factory Reset and Wipe cache partition from Recovery Mode. Try to write different firmwares one by one. |
09-23-2017, 09:53 | #8 (permalink) |
No Life Poster Join Date: Dec 2011
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | disconnect lcd connector on pcb and power on check startup tone startup tone working its lcd problem cheng display |
The Following User Says Thank You to mak1983 For This Useful Post: |
