10-20-2017, 06:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | j200gu dead after remove frp customer brought a j200gu hang on logo, when i check it is frp on. so i tried to remove it using octopus via download mode, it is done on octopus but phone restart on hang logo then off. no power. when i try it again, octopus said there is no pit in the partition. then i tried flashing combination file because frp is still on, but when i try to flash, it always says there is no pit in the partition. then when i remove battery to check model and put it back, phone will not power on again. and it was detected as deadboot on device manager of my laptop when i press power, it just pop a few seconds then disconnect. so it was deadboot.. i have done a lot of samsungs on octopus, just wandering what happened. |
10-20-2017, 06:41 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. At first post here full Software log with all operations, performed with the phone, we will check. |
10-20-2017, 07:18 | #3 (permalink) |
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | it is on another pc i have. there is no error and logs is just the same as others. when i click remove frp ee, it downloaded firmware from server, asked phone to be put to download mode, then all is okay, no error. but when phone reboots, samsung just blinks then screen is off, not turning on again. then when i try to redo the process, it said error, there is no pit on phone. then, i remove battery and try to turn phone on again, but no power. then i connect to usb and press power, the laptop detected it when i press power but just for 2 seconds then disconnected.. i just told the owner i think emmc is the problem. i am just curious why it died. |
10-20-2017, 07:36 | #4 (permalink) |
Freak Poster Join Date: Jul 2013 Location: sialkot
Member: 1972648 Status: Offline Thanks Meter: 45 | emmc chip is damaged emmc chip is damaged so try to bootrepair dont west time on flashing sir im 100% sure |
The Following User Says Thank You to zzaheerr For This Useful Post: |
