08-19-2017, 07:13 | #1 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | j320az unlock problem kindly help me ........ also try with old patch file but give error on sboot or give me other solution Sir ....... |
08-19-2017, 07:24 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. You can try to downgrade phone's firmware (write older, by release date, version of firmware) but on your own risk, after repeat Unlock or Write Cert operations. Unfortunately, we don't have any other solution at the moment. Also, please post here full Software log with all performed operations. |
08-19-2017, 07:36 | #3 (permalink) |
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | Welcome to Octoplus/Octopus Box Samsung software version 2.5.7 ----------------------------------------------------------------------------------- To connect SM-J320AZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: SM-J320AZ Mode: Emergency Codes for SM-J320AZ phone in emergency mode can’t be read Performed by 2.5.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J320AZ Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging. Please, press "OK" button on the phone to allow USB debugging. Warning: Selected model (SM-J320AZ) differs from the detected one (SM-J321AZ)! If you want select (SM-J321AZ) as (SM-J320AZ) model, please check "manual select". Performed by 2.5.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: SM-J320AZ Mode: Emergency Codes for SM-J320AZ phone in emergency mode can’t be read Performed by 2.5.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J320AZ Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging. Please, press "OK" button on the phone to allow USB debugging. Warning: Selected model (SM-J320AZ) differs from the detected one (SM-J321AZ)! If you want select (SM-J321AZ) as (SM-J320AZ) model, please check "manual select". Performed by 2.5.7 Software version. ----------------------------------------------------------------------------------- To connect SM-J321AZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: SM-J321AZ Mode: Emergency Codes for SM-J321AZ phone in emergency mode can’t be read Performed by 2.5.7 Software version. ----------------------------------------------------------------------------------- To connect SM-J320A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: SM-J320A Mode: Emergency Codes for SM-J320A phone in emergency mode can’t be read Performed by 2.5.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J320A Searching for a phone. Please wait... Found phone on COM166 Reading info... Detected phone model: SM-J321AZ HW Version: SM2J320AZWZAIO PDA version: J320AZTUS3AQD2 CSC version: J321AZAIZ3AQD2 CP version: J321AZTUS3AQD2 Phone SN: R28J11T8TYJ Phone IMEI: 356519-07-834479-2 Unlocking phone... Fast Unlock method is not supported for current security settings in your phone! Try to downgrade firmware! Phone unlocking failed Performed by 2.5.7 Software version. not downgraded ............. give error with old firmware |
08-19-2017, 08:15 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | As we can see from the Software log, your phone's model is SM-J321AZ, please select correct phone model and try to perform Unlock operation according to the Software manual. Note: we don't provide support for converted devices. |
