10-23-2017, 00:44 | #1 (permalink) |
No Life Poster Join Date: May 2014
Member: 2188956 Status: Offline Thanks Meter: 29 | J320V FRP say sucess but failed ----------------------------------------------------------------------------------- To connect SM-J320AZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SM-J320V Reset FRP/ Reactivation lock operation for SM-J320V will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J320V into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SM-J320V Reset FRP/ Reactivation lock operation for SM-J320V will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J320V into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.0 Software version. |
10-23-2017, 05:59 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Quote:
