02-28-2017, 05:20 | #1 (permalink) |
Freak Poster Join Date: Dec 2012 Location: chinnasalem tamilnadu india
Member: 1849338 Status: Offline Sonork: 100.1646373 Thanks Meter: 89 | J700f/ds frp lock remove in a min. INFO : 27-02-2017 11:39:14 > ----------------------------------------------------------------------------------- INFO : 27-02-2017 11:39:14 > To connect SM-G925F phone you have to perform the following steps: INFO : 27-02-2017 11:39:14 > 1. Disconnect USB cable from phone. INFO : 27-02-2017 11:39:14 > 2. Go to Menu->Settings->More->About Device. INFO : 27-02-2017 11:39:14 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 27-02-2017 11:39:14 > 4. Go to Menu->Settings->More->Developer options. INFO : 27-02-2017 11:39:14 > 5. Turn on "USB Debugging" option. INFO : 27-02-2017 11:39:23 > ----------------------------------------------------------------------------------- INFO : 27-02-2017 11:39:23 > To connect SM-J700F phone you have to perform the following steps: INFO : 27-02-2017 11:39:23 > 1. Disconnect USB cable from phone. INFO : 27-02-2017 11:39:23 > 2. Go to Menu->Settings->More->About Device. INFO : 27-02-2017 11:39:23 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 27-02-2017 11:39:23 > 4. Go to Menu->Settings->More->Developer options. INFO : 27-02-2017 11:39:23 > 5. Turn on "USB Debugging" option. INFO : 27-02-2017 11:40:22 > ----------------------------------------------------------------------------------- INFO : 27-02-2017 11:40:23 > Platform: Samsung Android INFO : 27-02-2017 11:40:23 > Selected port: COM1 INFO : 27-02-2017 11:40:23 > Selected model: SM-J700F WARN : 27-02-2017 11:40:24 > Reset FRP/ Reactivation lock operation for SM-J700F will delete all user data on the phone (contacts, pictures and others)! WARN : 27-02-2017 11:40:24 > WARN : 27-02-2017 11:40:24 > NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. WARN : 27-02-2017 11:40:24 > Connecting to server... INFO : 27-02-2017 11:40:27 > Connecting to server...Ok! INFO : 27-02-2017 11:40:27 > Checking resource files... INFO : 27-02-2017 11:40:29 > Resource files already downloaded. WARN : 27-02-2017 11:40:29 > Please put the phone into Download Mode and connect USB cable. WARN : 27-02-2017 11:40:32 > To put SM-J700F into Download Mode, You have to perform the following steps: WARN : 27-02-2017 11:40:32 > 1. Reconnect the battery. WARN : 27-02-2017 11:40:32 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 27-02-2017 11:40:32 > 3. When phone turns on, press "Volume+" key. INFO : 27-02-2017 11:40:32 > Waiting for phone... INFO : 27-02-2017 11:40:32 > Firmware write started. INFO : 27-02-2017 11:40:32 > Writing Custom section... INFO : 27-02-2017 11:40:35 > Custom section has been written successfully. WARN : 27-02-2017 11:40:35 > FRP lock is successfully reseted! BINF : 27-02-2017 11:40:35 > Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" INFO : 27-02-2017 11:40:35 > Performed by 2.4.8 Software version. Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\27-02-2017_11-37-21.log" closed (27-02-2017 11:41:40). Last edited by Octopus box; 02-28-2017 at 07:55. |
The Following User Says Thank You to amurale72 For This Useful Post: |
