04-20-2016, 11:34 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. Try to reflash the phone with older (by release date) firmwares, then repeat "Reset FRP/Reactivation/EE" operation. |
04-20-2016, 11:37 | #3 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
all file flash done FRP not done | |
04-20-2016, 11:51 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Currently we can't say which of older firmwares exactly will allow to safely "downgrade" and then remove FRP lock for this model. |
04-20-2016, 17:29 | #5 (permalink) |
Insane Poster Join Date: Jan 2014
Member: 2116325 Status: Offline Thanks Meter: 15 | problem with me too here is log- Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-J700F To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock.. Operation was failed! Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Platform: Samsung Android Selected port: COM7 Selected model: SM-J700F To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.4 software version |
04-21-2016, 19:20 | #7 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Tanzania
Member: 14229 Status: Offline Thanks Meter: 135 | Downgrading SM-N910H With odin always failed because bootloader is locked or secured. I found a 4 files ROM J700FXXU1AOFJ_OJV1AOFJ_Arabic_v5.1.1_Repair_Firmwa re and could not be flashed I tried to extract BL_J700FXXU1AOFJ ( bootloader ) with 7-Zip. To get sboot.bin. Once you have extracted sboot.bin use this https://mega.nz/#!7913nCxY to pack to tar then flash with odin. You can now use you box to reset frp lock |
04-24-2016, 19:32 | #9 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Use my gift for J700F Full Tested with Build "XXU1AOL2" Link: free-gift-all-octopus-users-big-list-frp-reset-files BR allumts |
10-26-2016, 16:45 | #10 (permalink) |
No Life Poster Join Date: May 2016 Location: ..:: BHARATH ::.. Age: 34
Member: 2569641 Status: Offline Sonork: WHATS APP & F.B Thanks Meter: 657 | samsung j700f flashing (and) remove google acount (frp) done in octopus box download letest firmwere on octopus shell... open octopus setup... select model and load firmwere... tick on advance mode... click on write firmwere... conect mobile in download... tick on only...........................system.img tick on..................................cache.img tick on..................................hidden.img tick on..................................modem.bin click on write....... flashing. done. ofter flashing reset frp ...............try OTG proces...https://www.youtube.com/watch?v=puGqsZzap7U done frp.... this proces tested by me....... |
The Following User Says Thank You to krishmobitech For This Useful Post: |
10-26-2016, 20:51 | #11 (permalink) |
No Life Poster Join Date: Oct 2002 Location: tunisia
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | sorry sir not working for Model: SM-J700F AP version: J700FXXU3BPJ1 CSC version: J700FOJV3BPJ1 CP version: J700FXXU3BPJ1 tested many tricks and firmwares trying to downgrade, all attempts failed looking for a working solution! |
10-27-2016, 13:32 | #13 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | flash with this fimware J700F BY VICKYJADHAV6161 - Download - 4shared - vicky jadhav then manuealy facory reset ,wipe data cach by useing keys....and follow this steaps.. Download and install sidesync on your pc Samsung SideSync 4.0 Open sidesync and connet u r phone to pc Now see on u r phone..... new window open In this window choose internet browser Now enter in url alnajat.Co/setting.Apk this app downloading auto but u cant see...Dont worry Go to bookmarks history download history and install setting.Apk Go to setting and Go to easy mode and choose choose standard mode, but here some time phone cant appears in normal mode dont worry, Keep repeating same process until the home screen appears in normal mode... now when u see phone in normal mode go to setting, turn on usb debug, oem unlock and Factory reset...... |
The Following User Says Thank You to vickyjadhav6161 For This Useful Post: |
11-29-2016, 09:17 | #14 (permalink) |
Member: 2569641 Status: Offline Sonork: WHATS APP & F.B Thanks Meter: 657 | Its working 1000% sir but you try octopus firmwere in octopus box.... i am tested this proces... |
