11-26-2016, 13:02 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: BANGLADESH Age: 34
Member: 1199125 Status: Offline Sonork: 100.1609676 Thanks Meter: 297 | J700F frp remove successfuly with Octopus Samsung tool 2.4.5 |
The Following 2 Users Say Thank You to GSM_HABIB For This Useful Post: |
11-26-2016, 13:11 | #3 (permalink) |
Freak Poster Join Date: Mar 2005 Location: uae Age: 35
Member: 129149 Status: Offline Sonork: 100.1638990 Thanks Meter: 20 | Welcome to Octoplus/Octopus Box Samsung software version 2.4.5 ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J700F Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Backup and reset" and make "Factory data reset" Performed by 2.4.5 Software version. ----------------------------------------------------------------------------------- To connect SM-G935F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G935F Connecting to server... Connecting to server...Ok! Checking resource files... Operation cancelled! Performed by 2.4.5 Software version. VERY VERY THANK TEAM Octopus Octoplus |
The Following 3 Users Say Thank You to bahsar333 For This Useful Post: |
11-27-2016, 12:24 | #4 (permalink) |
Member: 1199125 Status: Offline Sonork: 100.1609676 Thanks Meter: 297 | J500f frp remove successfully Code: INFO : 11/27/2016 1:57:37 PM > Platform: Samsung Android INFO : 11/27/2016 1:57:37 PM > Selected port: COM3 INFO : 11/27/2016 1:57:37 PM > Selected model: SM-J500F WARN : 11/27/2016 1:57:37 PM > Connecting to server... INFO : 11/27/2016 1:57:40 PM > Connecting to server...Ok! INFO : 11/27/2016 1:57:40 PM > Checking resource files... INFO : 11/27/2016 1:57:41 PM > Resource files already downloaded. WARN : 11/27/2016 1:57:41 PM > Please put the phone into Download Mode and connect USB cable. WARN : 11/27/2016 1:57:41 PM > To put SM-J500F into Download Mode, You have to perform the following steps: WARN : 11/27/2016 1:57:41 PM > 1. Reconnect the battery. WARN : 11/27/2016 1:57:41 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 11/27/2016 1:57:41 PM > 3. When phone turns on, press "Volume+" key. INFO : 11/27/2016 1:57:41 PM > Waiting for phone... INFO : 11/27/2016 1:57:41 PM > Firmware write started. INFO : 11/27/2016 1:57:42 PM > Writing Custom section... INFO : 11/27/2016 1:57:48 PM > Custom section has been written successfully. WARN : 11/27/2016 1:57:48 PM > FRP lock is successfully reseted! BINF : 11/27/2016 1:57:48 PM > Wait 3-4 min then goto "Backup and reset" and make "Factory data reset" INFO : 11/27/2016 1:57:48 PM > Performed by 2.4.5 Software version |
The Following User Says Thank You to GSM_HABIB For This Useful Post: |
