02-20-2016, 12:07 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: ==WORLD== Age: 49
Member: 79065 Status: Offline Sonork: 100.1646746 Thanks Meter: 79 | j700h frp problem Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-J700F To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.2.1 software version |
02-20-2016, 14:30 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. Try to reflash the phone with older firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
02-24-2016, 16:51 | #4 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Kolkata, India Age: 53
Member: 1164699 Status: Offline Thanks Meter: 62 | After pressed 'reset frp key/reactivation key/EE' tab. at info: Frp lock....success Resetting EE lock... success. Then handset react by showing downloading buffering bar with 99% appox. complete with white color. but not completing 100%. It is also showing downloading... do not turn off target. Did any one unlock frp J700F by octopus? Help me soon plz. |
02-24-2016, 17:04 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. Try to reflash the phone with older version of firmware (by release date), then repeat "Reset FRP/Reactivation/EE" operation. Also look here: http://forum.gsmhosting.com/vbb/f684...olved-2052467/ http://forum.gsmhosting.com/vbb/f684...click-2049313/ |
