11-24-2016, 08:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | j700h screen lock INFO : 11/24/2016 10:55:34 ق.ظ > Platform: Samsung Android INFO : 11/24/2016 10:55:34 ق.ظ > Selected port: COM5 INFO : 11/24/2016 10:55:34 ق.ظ > Selected model: SM-J700H WARN : 11/24/2016 10:55:34 ق.ظ > Connecting to server... INFO : 11/24/2016 10:55:36 ق.ظ > Connecting to server...Ok! INFO : 11/24/2016 10:55:36 ق.ظ > Checking resource files... INFO : 11/24/2016 10:55:37 ق.ظ > Resource files already downloaded. WARN : 11/24/2016 10:55:37 ق.ظ > Please put the phone into Download Mode and connect USB cable. WARN : 11/24/2016 10:55:39 ق.ظ > To put SM-J700H into Download Mode, You have to perform the following steps: WARN : 11/24/2016 10:55:39 ق.ظ > 1. Reconnect the battery. WARN : 11/24/2016 10:55:39 ق.ظ > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 11/24/2016 10:55:39 ق.ظ > 3. When phone turns on, press "Volume+" key. INFO : 11/24/2016 10:55:39 ق.ظ > Waiting for phone... INFO : 11/24/2016 10:55:39 ق.ظ > Firmware write started. INFO : 11/24/2016 10:55:40 ق.ظ > Writing Custom section... INFO : 11/24/2016 10:55:43 ق.ظ > Custom section has been written successfully. WARN : 11/24/2016 10:55:43 ق.ظ > Reset Screen Lock successfully completed. INFO : 11/24/2016 10:55:43 ق.ظ > Performed by 2.4.4 Software version. Last edited by Octopus box; 11-28-2016 at 17:53. |
11-24-2016, 09:24 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Hello. Unfortunately new reset Screen Lock method removes user data. Currently this is the only way for phones with new firmwares. We'll try to improve the solution in future. |
11-26-2016, 10:19 | #3 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | hello test by other phone not work and delete all deta on my phone (android6) and after unlock: j700f total memory 16 after unlock only 4 show in phone please remove this metod Welcome to Octoplus/Octopus Box Samsung software version 2.4.5 ----------------------------------------------------------------------------------- To connect GT-S7710 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "PDA" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-J700F Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. Reset Screen Lock successfully completed. Performed by 2.4.5 Software version. |
11-28-2016, 17:51 | #5 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | Quote:
Screen lock is stored in "data" partition - if you factory reset the device, the screen lock will be gone. FRP is not stored in "data" - if you factory reset the device, FRP will still be there. | |
The Following User Says Thank You to namos23 For This Useful Post: |
