10-17-2016, 09:12 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: The Great India
Member: 1004995 Status: Offline Thanks Meter: 230 | l720t unable to connect Logs Welcome to Octoplus/Octopus Box Samsung software version 2.3.9 ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM65 Selected model: SPH-L720T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM65 Mode: Emergency Phone connection failed No diagnostic ports found! Performed by 2.3.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM65 Selected model: SPH-L720T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM65 Mode: Emergency Phone connection failed No diagnostic ports found! Performed by 2.3.9 Software version. Pls guide. Regds Narendra Singh |
10-17-2016, 09:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. To connect SPH-L720T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090# or *#0808#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. |
