01-18-2014, 10:31 | #1 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2097474 Status: Offline Thanks Meter: 0 | M919 4.2.2 cant unlock! here the log: Mode: Emergency ------------------------------------------------------------------------------------------ Platform: Samsung Android Selected port: COM16 Selected model: SGH-M919 Reading info, please wait... Detected phone model: SGH-M919 Firmware compiled date: Fri Apr 26 17:15:31 KST 2013 PDA version: M919UVUAMDL CSC version: M919TMBAMDL SW version: M919UVUAMDL Phone IMEI: 356...051...150 Phone SN: RV1D...85SP Android version: 4.2.2 (JDQ39) ------------------------------------------------------------------------------------------ Platform: Samsung Android Selected port: COM16 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM16 Mode: Emergency ------------------------------------------------------------------------------------------ Platform: Samsung Android Selected port: COM16 Selected model: SGH-M919 Mode: Emergency Unlock for SGH-M919 phone in emergency mode can’t be done ------------------------------------------------------------------------------------------ Platform: Samsung Android Selected port: COM16 Selected model: SGH-M919 Mode: Emergency Codes for SGH-M919 phone in emergency mode can’t be read ------------------------------------------------------------------------------------------ Platform: Samsung Android Selected port: COM16 Selected model: SGH-M919 Mode: Emergency Unlock for SGH-M919 phone in emergency mode can’t be done ------------------------------------------------------------------------------------------ Platform: Samsung Android Selected port: COM16 Selected model: SGH-M919 Mode: Emergency Unlock for SGH-M919 phone in emergency mode can’t be done ------------------------------------------------------------------------------------------ Platform: Samsung Android Selected port: COM16 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM16 Mode: Emergency ------------------------------------------------------------------------------------------ Platform: Samsung Android Selected port: COM16 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM16 Mode: Emergency ------------------------------------------------------------------------------------------ Platform: Samsung Android Selected port: COM16 Selected model: SGH-M919 Mode: Emergency Unlock for SGH-M919 phone in emergency mode can’t be done ------------------------------------------------------------------------------------------ Platform: Samsung Android Selected port: COM16 Selected model: SGH-M919 Mode: Emergency Unlock for SGH-M919 phone in emergency mode can’t be done ------------------------------------------------------------------------------------------ Platform: Samsung Android Selected port: COM16 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM16 Mode: Emergency plz help |
01-18-2014, 10:45 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to connect the phone via Micro USB cable. To connect SGH-M919 via Micro USB cable, You have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Enter "*#0808#" number. 9. Select "DM+Modem+ADB". 10. Go to "Qualcomm USB Settings". 11. Select "DM+Modem+ADB". 12. Close window. 13. Go to dial window. 14. Enter "*#9090#" number. 15. Set "Diag config" to "USB" value. 16. Restart phone. 17. Press "Read Info" in software. If the phone will not be connected via Micro USB cable, try to connect it via Samsung Micro UART C3300k/C3303k cable. To connect SGH-M919 phone via Samsung Micro UART cable, do the next steps: 1. Disconnect Samsung Micro UART cable from phone. 2. Go to dial window. 3. Enter "*#7284#" number. 4. Set "UART" radio button to "MODEM" value. 5. Go to "Qualcomm USB Settings". 6. Select "DM+Modem+ADB". 7. Close window. 8. Go to dial window. 9. Enter "*#9090#" number. 10. Set "Diag config" to "UART" value. 11. Restart phone. 12. Press "Read Info" in software. |
01-18-2014, 13:13 | #4 (permalink) |
Member: 2097474 Status: Offline Thanks Meter: 0 | i have another diag config when i do *#9090# witout UART and USB this is what i have : DM-DUM over HS-USB DM-DUM over HSIC DM-DUN-RmNET over HSUSB DM over UART DBG MSG ON DBG MSG OFF Last edited by doronbxx; 01-18-2014 at 13:22. |
01-18-2014, 13:49 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If You try to connect the device via Micro USB cable, please select "DM-DUM over HS-USB" (also, try to select "DM-DUM over HS-USB"). If You try to connect via Samsung Micro UART C3300k/C3303k cable - select "DM over UART" . |
