06-02-2014, 20:04 | #1 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2059895 Status: Offline Thanks Meter: 0 | M919 4.4.2 Unlock & Repair IMEI Problem I tried to unlock M919 4.4.2 then it lost IMEI number (Unknown). I was not able to repair IMEI either. Do you have any solution? Thanks Platform: Samsung Android Selected port: COM107 Selected model: SGH-M919 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 14 2014 Firmware released time: 15:28:19 SW version: M9615A-CEFWTAZM-4.0.17135 Old IMEI: 004400-15-202000-0 New IMEI: 358011-05-456776-8 Creating NVM backup Reading NVM done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\NVM-SGH-M919-004400152020000-02-06-2014_14-58-45-.nvm file Firmware compiled date: Fri Feb 14 14:44:35 KST 2014 PDA version: M919UVUFNB4 CSC version: M919TMBFNB4 SW version: M919UVUFNB4 Phone IMEI: Unknown Phone SN: RV8F10PM3NZ Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 14 2014 Firmware released time: 15:28:19 SW version: M9615A-CEFWTAZM-4.0.17135 Found phone on COM107 Repairing NVM for SGH-M919 phone... Write IMEI failed |
06-02-2014, 20:49 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please try to do the next: 1. Install the latest Software version (Software). 2. Make "Repair EFS". 3. Write modem firmware "SGH-M919_modem_CWM_UVUAMDL". 4. Make "Repair NVM". 5. Perform "Repair IMEI" operation. 6. Post here the result. |
06-02-2014, 21:10 | #3 (permalink) |
Major Poster Join Date: Apr 2006
Member: 256252 Status: Offline Thanks Meter: 16 | 1. Install the latest Software version (Software). 2. Make "Repair EFS". 3. Write modem firmware "SGH-M919_modem_CWM_UVUAMDL". 4. Root the phone. 5. Perform "Repair IMEI" operation. 6. Flash stock 4.4.2 stock firmware or just the 4.4.2 modem back. |
06-02-2014, 21:20 | #5 (permalink) |
Member: 2059895 Status: Offline Thanks Meter: 0 | Platform: Samsung Android Selected port: COM107 Selected model: SGH-M919 Reading info, please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM107 Selected model: SGH-M919 Reading info, please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Detected phone model: SGH-M919 Firmware compiled date: Fri Feb 14 14:44:35 KST 2014 PDA version: M919UVUFNB4 CSC version: M919TMBFNB4 SW version: M919UVUFNB4 Phone IMEI: Unknown Phone SN: RV8F10PM3NZ Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM106 Selected model: SGH-M919 Reading info, please wait... ADB server killed. Detected phone model: SGH-M919 Firmware compiled date: Fri Feb 14 14:44:35 KST 2014 PDA version: M919UVUFNB4 CSC version: M919TMBFNB4 SW version: M919UVUFNB4 Phone IMEI: Unknown Phone SN: RV8F10PM3NZ Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM106 Selected model: SGH-M919 Phone was not found on the selected port! To put SGH-M919 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Repairing EFS... Searching for a phone. Please wait... Phone found. Repair EFS failed |
06-03-2014, 08:30 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please do the next: 1. Install the latest Software version (Software). 2. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 3. Run Octoplus Samsung Software. 4. Re-start the phone. 5. Perform "Repair EFS" operation. 6. Close the Software. 7. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the link, we will research, where can be the problem with your device. |
06-03-2014, 16:35 | #7 (permalink) | |
No Life Poster Join Date: Oct 2013
Member: 2051392 Status: Offline Thanks Meter: 161 | Quote:
1. Write back the security backup to the phone to restore original IMEI. 2. You have to downgrade the modem(baseband) of the phone to MLG that's from 4.2.2 at this point you will lose sound, don't worry about this now we fix it later. 3. Root if is not rooted, you can use Kingo Root for that. 4. Now run the IMEI Repair and it will go thru without a problem. 5. After repair is finished download the 4.4.2 stock ROM and flash it thru Odin to fix the sound. 6. That's it all done IMEI fixed and everything working. | |
06-03-2014, 21:02 | #10 (permalink) | |
Member: 2059895 Status: Offline Thanks Meter: 0 | Quote:
mediafire.com/?p3gbuuae53tnegh | |
06-03-2014, 21:07 | #11 (permalink) |
Member: 2051392 Status: Offline Thanks Meter: 161 | The software does it automatically check in C:/Program files/Octoplus/Octoplus_Samsung/Backup and there check for your security back, look for the one with your IMEI Number the one on the back or the one you first started to do the repair and the copy it to your desktop to find it easily then go to the software and hit Read Phone then Write Security to the phone. Sent from my SAMSUNG-SGH-I317 using Tapatalk |
06-04-2014, 20:59 | #12 (permalink) |
Member: 2051392 Status: Offline Thanks Meter: 161 | I just did one today and it worked flawless I used CF Root to root it, did the downgrade, the IMEI Repair and restored modem and all worked Sent from my SAMSUNG-SGH-I317 using Tapatalk |
