06-15-2016, 11:47 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | menu model number n9005-but odin mode sm-n900p -ntwk problem erase security -then imei 01,write certificate,then write qcn,then repair 3g but this when write certificate error as below Platform: Samsung Android Selected port: COM1 Selected model: SM-N9005 Reading info, please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N9005 Firmware compiled date: Thu Nov 5 22:10:50 KST 2015 PDA version: N9005XXUGBNL8 CSC version: N9005XXUGBNL8 SW version: Unknown Android version: 5.0 (LRX21V) Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N9005 Detected phone model: SM-N9005 Firmware compiled date: Thu Nov 5 22:10:50 KST 2015 PDA version: N9005XXUGBNL8 CSC version: N9005XXUGBNL8 SW version: Unknown Android version: 5.0 (LRX21V) Reading info... Phone was not found on the selected port! Performed by 2.2.1 software version tried all ways can not-first time i saw odin mode model number sm-n900p and in menu model number sm-n9005 any way to get network? |
06-15-2016, 12:23 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Hello. As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Write Cert" operation. It is not possible to repair IMEI, if phone's modem part is damaged. If after writing of all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). | |
06-15-2016, 14:29 | #3 (permalink) | |
Member: 946381 Status: Offline Thanks Meter: 150 | Quote:
menu baseband version ok as """"N9005XXUGBNL8"""-imei also as 357507053331115 in dubai this phone using with out any problem-in india network problem | |
