06-08-2014, 18:50 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ S.Leo What is the history of your device? After of which operations exactly your device got this issue? Are You sure this is not HW problem? Try to make Repair EFS, Repair IMEI, Unlock and re-flash the device. |
06-08-2014, 19:41 | #5 (permalink) |
No Life Poster Join Date: Apr 2007
Member: 485779 Status: Offline Thanks Meter: 135 | Welcome to Octoplus/Octopus Box Samsung software version 1.5.7 ----------------------------------------------------------------------------------- To connect GT-N7000 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM267 Selected model: GT-N7000 Detected phone model: GT-N7000 Firmware compiled date: Tue Feb 19 21:38:01 KST 2013 PDA version: N7000JPLSB CSC version: N7000OJPLSB SW version: Unknown Phone IMEI: Unknown Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-N7000-Unknown08-06-2014_21-37-50-.asec file Cheking security type... Old security type is detected Old IMEI: Unknown New IMEI: 35xxxx-xx-xxxxxx-6 Repairing IMEI ... Executing exploit... Exploit has been executed successfully Unknown security Write IMEI failed |
The Following User Says Thank You to S.Leo For This Useful Post: |
06-09-2014, 06:28 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As You can see from your Software log, phone's modem part is damaged: Quote:
At first, try to re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct), perform "Repair EFS" and "Repair IMEI" operatios. It is not possible to repair IMEI, if phone's modem part is damaged. | |
06-09-2014, 10:05 | #8 (permalink) |
Member: 485779 Status: Offline Thanks Meter: 135 | Welcome to Octoplus/Octopus Box Samsung software version 1.5.7 ----------------------------------------------------------------------------------- To connect GT-N7000 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-N7000 Detected phone model: GT-N7000 Firmware compiled date: Tue Jul 31 18:39:48 KST 2012 PDA version: N7000JPLR8 CSC version: N7000OJPLR8 SW version: Unknown Phone IMEI: Unknown Android version: 4.0.4 (IMM76D) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-N7000-Unknown09-06-2014_11-54-46-.asec file Cheking security type... Old security type is detected Old IMEI: Unknown New IMEI: 35xxxx-xx-xxxxxxxxx Repairing IMEI ... Executing exploit... hang here I downgrade the set change the last number of imei but no luck ......... any solution ............ |
06-09-2014, 10:13 | #9 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Carefully read what I have written above: Phone's modem part is damaged in your phone: Quote:
Try to re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct), perform "Repair EFS" and "Repair IMEI" operatios. It is not possible to repair IMEI, if phone's modem part is damaged. | |
06-09-2014, 11:26 | #10 (permalink) |
Member: 485779 Status: Offline Thanks Meter: 135 | As my first post all thing is ok Baseband and imei and sn is ok emergency calls only ----------------------------------------------------------------------------------- INFO : 08-Jun-14 1:24:41 PM > Platform: Samsung Android INFO : 08-Jun-14 1:24:41 PM > Selected port: COM109 INFO : 08-Jun-14 1:24:41 PM > Selected model: GT-N7000 INFO : 08-Jun-14 1:24:41 PM > Reading info, please wait... INFO : 08-Jun-14 1:24:41 PM > Detected phone model: GT-N7000 INFO : 08-Jun-14 1:24:41 PM > Firmware compiled date: Tue Feb 19 21:38:01 KST 2013 INFO : 08-Jun-14 1:24:42 PM > PDA version: N7000JPLSB INFO : 08-Jun-14 1:24:42 PM > CSC version: N7000OJPLSB INFO : 08-Jun-14 1:24:43 PM > SW version: N7000XXLSO INFO : 08-Jun-14 1:24:44 PM > Phone IMEI: 35xxxxxxxxxxxx INFO : 08-Jun-14 1:24:44 PM > Phone SN: RF1xxxxxxxxx INFO : 08-Jun-14 1:24:44 PM > Android version: 4.1.2 (JZO54K) then I Repair EFS after that it not Repair IMEI |
