12-21-2013, 13:22 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Yangon
Member: 550683 Status: Offline Sonork: 100.1649601 Thanks Meter: 43 | n7100 after repair network NULL/NULL ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM376 Selected model: GT-N7100 Searching for a phone. Please wait... Phone found. Firmware compiled date: Mon Dec 9 10:37:56 KST 2013 Phone SN: R31C91ALCMV Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM376 Selected model: GT-N7100 Reading info, please wait... Detected phone model: GT-N7100 Firmware compiled date: Mon Dec 9 10:37:56 KST 2013 PDA Version: N7100XXUEML3 CSC Version: N7100OLBEML1 SW Version: N7100XXUEMK1 Phone IMEI: 353771054215602 Phone SN: R31C91ALCMV Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM376 Selected model: GT-N7100 Detected phone model: GT-N7100 Firmware compiled date: Mon Dec 9 10:37:56 KST 2013 PDA Version: N7100XXUEML3 CSC Version: N7100OLBEML1 SW Version: N7100XXUEMK1 Phone IMEI: 353771054215602 Phone SN: R31C91ALCMV Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Repairing network. Please wait, this can take some time... Phone will restart now Network is successfully repaired. i had baseband and imei .. i repair network all gone octopus team help me |
12-21-2013, 13:27 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Repair Network for this device with 4.3 Android version is currently not supported. To return your device into the previous state, please re-flash it with the same firmware version. |
12-21-2013, 13:31 | #3 (permalink) |
Member: 550683 Status: Offline Sonork: 100.1649601 Thanks Meter: 43 | Platform: Samsung Android Selected port: COM376 Selected model: GT-N7100 Reading info, please wait... Detected phone model: GT-N7100 Firmware compiled date: Mon Dec 9 10:37:56 KST 2013 PDA Version: N7100XXUEML3 CSC Version: N7100OLBEML1 Android version: 4.3 (JSS15J) ARE YOU SURE I GET BACK BASEBAND AND IMEI??? |
12-21-2013, 14:10 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Currently no solution for this device with Android 4.3 verison how to make Repair Network. We work on this problem. You can try to downgrade the firmware version and then make Repair Network; but if your device has secured boot loader, your device can be damaged during of downgrade process. So, You can try to do this for your own risk or wait for solution. Also, to repair network (to make network active), try to write Service IMEI on "Repair IMEI / SN" tab in Software and the post the result here. After You will change IMEI to Service one, network should be available. |
12-21-2013, 14:22 | #8 (permalink) |
Member: 550683 Status: Offline Sonork: 100.1649601 Thanks Meter: 43 | i try many time downgrade odin flash failed..... phone was imei 00499 i try repair imei with z3x failed....also try octopus failed...but spt with done....i got imei but cant make call...only Emergency calls only |
12-22-2013, 04:11 | #11 (permalink) |
No Life Poster Join Date: Aug 2008 Location: PhnomPenh Cambodia
Member: 846616 Status: Offline Sonork: 100.1675590 Thanks Meter: 581 | @rubymunna if get error imei after downgrade u can use octoplus to repair imei with the last version only one click can solve your problem |
12-22-2013, 13:22 | #13 (permalink) | |
Member: 550683 Status: Offline Sonork: 100.1649601 Thanks Meter: 43 | Quote:
Sent from my iPhone using Tapatalk | |
