07-16-2014, 11:43 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: England Manchester
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | N7100 CSC:version unkown. Welcome to Octoplus/Octopus Box Samsung software version 1.6.0 ----------------------------------------------------------------------------------- To connect SGH-I537 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM82 Selected model: SGH-I537 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM82 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SGH-I537 Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM82 Phone connection failed No diagnostic ports found! Connecting to phone on COM4 Phone connection failed ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM82 Selected model: GT-N7100 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Sep 25 18:12:10 KST 2013 PDA version: N7100XXUEMI6 CSC version: Unknown SW version: N7100XXEMI6 Phone IMEI: 353627057790944 Phone SN: 00000000000 Android version: 4.3 (JSS15J) |
07-16-2014, 14:04 | #3 (permalink) |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Welcome to Octoplus/Octopus Box Samsung software version 1.6.0 ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. Selected firmware file: AP_N7100XXUEM16_CP_N7100XXEM16 _CSC_N7100XAEM16.oct Please switch your phone to the download mode and connect it to a PC. To put GT-N7100 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM82 Selected model: GT-N7100 Searching for a phone. Please wait... ADB server killed. Phone found. Firmware compiled date: Wed Sep 25 18:12:10 KST 2013 PDA version: N7100XXUEMI6 CSC version: Unknown SW version: N7100XXEMI6 Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM82 Selected model: GT-N7100 Detected phone model: GT-N7100 Firmware compiled date: Wed Sep 25 18:12:10 KST 2013 PDA version: N7100XXUEMI6 CSC version: Unknown SW version: N7100XXEMI6 Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-N7100-Unknown16-07-2014_18-00-24-.asec file Cheking security type... New security type is detected Old IMEI: 004999-01-064000-0 New IMEI: 353627-05-779094-4 Repairing IMEI ... Executing exploit... Exploit has been executed successfully Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now IMEI successfully repaired. Please, restart the phone to apply changes |
07-16-2014, 15:06 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Yes, Quote:
