04-01-2015, 15:49 | #1 (permalink) |
Moderator Join Date: Dec 2010 Location: Malaysia
Member: 1464783 Status: Offline Thanks Meter: 1,091 | N7100....I9300 write Cert Not Support....Need Update [Solved] Please Update N7100....I9300 write Cert Option...TQ BR Nizda Mobile Last edited by Octopus box; 04-01-2015 at 16:26. |
04-01-2015, 15:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Do You have these devices in hands now? |
04-01-2015, 15:57 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Root the phone, connect it as GT-I9500 and try to read out IMEI Certificate. Post here the result. |
04-01-2015, 16:08 | #6 (permalink) |
Member: 1464783 Status: Offline Thanks Meter: 1,091 | Not working.... Welcome to Octoplus/Octopus Box Samsung software version 1.9.0 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Warning: Selected model (GT-I9500) differs from the detected one (GT- I9300)! If you want select (GT-I9300) as (GT-I9500) model, please check "manual select". Reading Certificate failed BR Nizda Mobile |
04-01-2015, 16:20 | #8 (permalink) |
Member: 1464783 Status: Offline Thanks Meter: 1,091 | yes.......working....tq Octopus team.... tick Manual option ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Selected file: D:\Nizda Mobile Documents\Flash File Area \Samsung\Samsung Cert And Qcn\CERT\Cert-GT-I9300_ 35371*********_RV1C62JM2VA.cert Detected phone model: GT-I9300 Firmware compiled date: Thu Jan 16 23:53:58 KST 2014 PDA version: I9300XXUGNA5 CSC version: I9300OLBGNB1 SW version: I9300DXUGNB1 Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Certificate is compatible Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes BR Nizda Mobile |
The Following User Says Thank You to Nizda Mobile For This Useful Post: |
