11-23-2013, 16:24 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Real First In The World Update IMEI Repair GT-I8262 Octopus Box Platform: Samsung Anycall Selected port: COM69 Selected model: GT-I8262 Mode: Normal Phone model: GT-I8262 Firmware compiled date: Apr 10 2013 Firmware compiled time: 03:00:00 Firmware released date: May 17 2013 Firmware released time: 18:17:33 SW Version: 8X25-SSOSKOLYM-2035 Old IMEI: 357XXX-XX-1793XX-8 New IMEI: 357XXX-XX-1794XX-7 Searching for a phone. Please wait... Firmware compiled date: Fri May 17 13:34:15 KST 2013 Phone SN: RF1D80E5T5M Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Network is successfully repair. Repairing IMEI ... New IMEI successfully written. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Platform: Samsung Anycall Selected port: COM69 Selected model: GT-I8262 Mode: Normal Phone model: GT-I8262 Firmware compiled date: Apr 10 2013 Firmware compiled time: 03:00:00 Firmware released date: May 17 2013 Firmware released time: 18:17:33 SW Version: 8X25-SSOSKOLYM-2035 Old IMEI B: 357XXX-XX-179XXX-7 New IMEI B: 357XXX-XX-179XXX-0 Searching for a phone. Please wait... Firmware compiled date: Fri May 17 13:34:15 KST 2013 Phone SN: RF1D80E5T5M Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Network is successfully repair. Repairing IMEI ... New IMEI successfully written. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) No Issue Like Other Boxes Fake Update After Change IMEI No Network But With Octopus Network Ok No Issue Last edited by ..::Rizwan::..; 11-23-2013 at 16:30. |
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post: |
06-25-2014, 11:48 | #2 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | im many try with octopus box but no luck for me Code: Phone model: GT-I8262 Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Aug 19 2013 Firmware released time: 17:16:37 SW version: 8X25-SSOSKOLYM-2035 Old IMEI: 004400-15-202000-0 New IMEI: 357786-05-419572-5 Searching for a phone. Please wait... Firmware compiled date: Mon Jul 22 17:18:15 KST 2013 PDA version: I8262XXAMG6 CSC version: I8262OLBBMH2 SW version: I8262DXAMH1 Phone IMEI: Unknown Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Write IMEI failed |
06-25-2014, 11:59 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Do the next: 1. Install the latest Software version (Software). 2. Root the phone and install the SU. Run the SU from the phone's menu and press "Allow" button on the phone every time when superuser dialog appears. If You can't root the device correctly, write the special firmware from the Support Area. 3. Perform the Repair IMEI operation again. 4. Post here the result. |
06-26-2014, 11:04 | #4 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
now my problem solved Code: Welcome to Octoplus/Octopus Box Samsung software version 1.5.9 ----------------------------------------------------------------------------------- To connect GT-I8262 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM444 Selected model: GT-I8262 Mode: Normal Phone model: GT-I8262 Firmware compiled date: Apr 10 2013 Firmware compiled time: 03:00:00 Firmware released date: May 17 2013 Firmware released time: 18:17:33 Phone IMEI: 357786-05-419572-5 SW version: 8X25-SSOSKOLYM-2035 ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM444 Selected model: GT-I8262 Mode: Normal Phone model: GT-I8262 Firmware compiled date: Apr 10 2013 Firmware compiled time: 03:00:00 Firmware released date: May 17 2013 Firmware released time: 18:17:33 SW version: 8X25-SSOSKOLYM-2035 Old IMEI: 357786-05-419572-5 New IMEI: 357786-05-419572-5 Please, enter the new IMEI ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM444 Selected model: GT-I8262 Mode: Normal Phone model: GT-I8262 Firmware compiled date: Apr 10 2013 Firmware compiled time: 03:00:00 Firmware released date: May 17 2013 Firmware released time: 18:17:33 SW version: 8X25-SSOSKOLYM-2035 Old IMEI: 357786-05-419572-5 New IMEI: 357786-05-419573-3 Searching for a phone. Please wait... Firmware compiled date: Fri May 17 13:34:15 KST 2013 PDA version: I8262XXAME8 CSC version: I8262OJVAME2 SW version: I8262JVAME1 Phone IMEI: 357786054195725 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Network is successfully repair. Repairing IMEI ... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) | |
