02-11-2013, 08:51 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: GSMHOSTING
Member: 1691378 Status: Offline Sonork: 100.1645448 Thanks Meter: 141 | N7100 imei repair 100% tested solution 2)root the phone with root file from support 3)dail *#9090# set 115200 4)dail *#7284# set uart to modem save and resart 5)now repair imei with octopus and using comp port from z3x box tested 10 times if works press thanks |
The Following 2 Users Say Thank You to AC-GSM971 For This Useful Post: |
02-22-2013, 13:23 | #5 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Rio de Janeiro - Brasil
Member: 797068 Status: Offline Thanks Meter: 75 | yes i´m version 1.8.0 Bemvindo na Octopus Box Samsung software versão 1.8.0 ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM87 Modelo seleccionado: GT-N7100 Searching for a phone. Please wait... Phone found. Data de criação do firmware: Wed Dec 26 10:30:55 KST 2012 Phone SN: RQ1CA10WM3Y Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM87 Modelo seleccionado: GT-N7100 Modelo do telefone detectado: GT-N7100 Data de criação do firmware: Wed Dec 26 10:30:55 KST 2012 Phone SN: RQ1CA10WM3Y Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Repairing network. Please wait, it can take some time... Network is successfully repaired. Erasing old IMEI. It can take some time. Please wait... O telefone se reiniciará agora After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Go to dial window. 3. Enter *#7284# number. 4. Set "UART" radio button to "MODEM" value. 5. Connect phone via UART cable to Box. (conectei na vigys COM 05) Connecting to phone, please wait... Found phone on COM5 Phone connected successfully Escrevendo novo IMEI do telefone... New IMEI successfully written. Para aplicar os câmbios, reinicie o telefone |
06-28-2013, 23:44 | #6 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Jeddah, Saudi Arabia
Member: 1911337 Status: Offline Thanks Meter: 38 | I have a galaxy note 2 facing the same problem (not registered on network), its bcz the mobile's IMEI is different from the IMEI shown in the back of the device. I tried to repair IMEI with z3x entering the basic IMEI and the IMEI successfully changed but still the problem is there (not registered on network). Is there any other thing to do? Is there any need to flash it after repairing IMEI? I need urgent help plz. Thanks in advance. |
The Following User Says Thank You to Abdullah Shafiq For This Useful Post: |
06-29-2013, 03:20 | #7 (permalink) | |
Member: 1691378 Status: Offline Sonork: 100.1645448 Thanks Meter: 141 | Quote:
Sent from my GT-I9003 using Tapatalk 2 | |
06-30-2013, 08:38 | #8 (permalink) |
Freak Poster Join Date: Jan 2008 Location: phone care
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | hello all friend.i also have more then 10 pcs n7100 note2 with null imei .i got that all died some one i repair with boot mathad some one i have to change emmc after change emmc mobile working fine but there is no imei its null.i try with all best box octopus z3x nspro spt all same phone not found .i talk with z3x support thay said if modem not found it mean 90% hardware .if hardware any one can tell me what i do in hardware..if there is option with software also plz tell me thanx for gsmhosting...all member. Last edited by Octopus box; 06-26-2014 at 10:06. |
06-26-2014, 10:04 | #10 (permalink) |
Junior Member Join Date: Mar 2008
Member: 725543 Status: Offline Thanks Meter: 0 | hi.. i have a problem with the serial number of n7100 --------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-N7100 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Sep 25 18:12:10 KST 2013 PDA version: N7100XXUEMI6 CSC version: N7100OXAEMI6 SW version: N7100XXEMI6 Phone IMEI: correct 354833052616378 Phone SN: 00000000000 Android version: 4.3 (JSS15J) --------------------------------------------------- the imei is correct but the phone have SN 000000 and the network is off you have solution ? thanks |
06-26-2014, 10:11 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Repair SN is currently not supported for this phone model. But, most likely, the problem not with SN. Try to do the next: 1. Install the latest Software version (Software). 2. Make Repair EFS. 3. Re-flash the device. 4. Perform the Unlock operation. 5. Make Repair IMEI. 6. Write here the result. |
06-26-2014, 10:29 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Yes, with the same or higher Android version. |
