08-02-2013, 03:15 | #1 (permalink) |
Crazy Poster Join Date: Aug 2013
Member: 1991826 Status: Offline Thanks Meter: 6 | N7100 octopus Box Write IMEI Failed |
08-02-2013, 03:25 | #3 (permalink) |
Member: 1991826 Status: Offline Thanks Meter: 6 | Plataforma: Samsung Android Puerto seleccionado: COM22 Modelo seleccionado: GT-N7100 Modelo del teléfono detectado: GT-N7100 Fecha de creación del firmware: Wed Dec 26 16:32:39 KST 2012 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Repairing network. Please wait, it can take some time... Network is successfully repaired. Erasing old IMEI. It can take some time. Please wait... El teléfono se reiniciará ahora After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Go to dial window. 3. Enter *#7284# number. 4. Set "UART" radio button to "MODEM" value. 5. Connect phone via UART cable to Box. Connecting to phone, please wait... Write IMEI failed |
08-02-2013, 04:00 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: india
Member: 1161713 Status: Offline Sonork: 100.1607798 Thanks Meter: 421 | Can u follow instruction ? 1. Disconnect USB cable. 2. Go to dial window. 3. Enter *#7284# number. 4. Set "UART" radio button to "MODEM" value. 5. Connect phone via UART cable to Box. |
The Following User Says Thank You to omkar3268 For This Useful Post: |
08-02-2013, 04:51 | #5 (permalink) |
Member: 1991826 Status: Offline Thanks Meter: 6 | New error Plataforma: Samsung Android Puerto seleccionado: COM22 Modelo seleccionado: GT-N7100 Modelo del teléfono detectado: GT-N7100 Fecha de creación del firmware: Wed Dec 26 16:32:39 KST 2012 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Repairing network. Please wait, it can take some time... Network is successfully repaired. Erasing old IMEI. It can take some time. Please wait... El teléfono se reiniciará ahora After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Go to dial window. 3. Enter *#7284# number. 4. Set "UART" radio button to "MODEM" value. 5. Connect phone via UART cable to Box. Connecting to phone, please wait... Found phone on COM22 Phone connected successfully Escribiendo nuevo IMEI del teléfono... Write IMEI failed |
08-02-2013, 07:33 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. What IMEI exatly is in your phone now (by *#06#)? Also, You can contact us to Sonork, Yahoo! Messenger or Skype, we will look where is the problem with your phone and try to help You remotely via Team Viewer. |
08-04-2013, 20:17 | #13 (permalink) |
Member: 1991826 Status: Offline Thanks Meter: 6 | im trying on other pc that have only 3 com ports and w7 x86: Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: GT-N7100 Modelo del teléfono detectado: GT-N7100 Fecha de creación del firmware: Wed Dec 26 10:30:55 KST 2012 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Repairing network. Please wait, it can take some time... Network is successfully repaired. Erasing old IMEI. It can take some time. Please wait... El teléfono se reiniciará ahora After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Go to dial window. 3. Enter *#7284# number. 4. Set "UART" radio button to "MODEM" value. 5. Connect phone via UART cable to Box. Connecting to phone, please wait... Found phone on COM3 Phone connected successfully Escribiendo nuevo IMEI del teléfono... Write IMEI failed |
08-04-2013, 20:33 | #15 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Dhaka.Bangladesh Age: 36
Member: 1828150 Status: Offline Sonork: 100.1617455 Thanks Meter: 29 | Step-1: Download CF-Auto-Root for Samsung Galaxy Note 2 to the computer [File name: CF-Auto-Root-to3g-to3gxx-gtn7100.zip] Step-2: Extract the downloaded CF-Auto-Root zip to get a file with .tar.md5 extension Step-3: Download Odin3 v3.07. Extract the zip to get Odin3 v3.07.exe along with few other files Step-4: Power off the Galaxy Note 2. Wait for five to six seconds for vibration to confirm complete switch off Step-5: Boot the phone into Download Mode by pressing and holding Volume Down + Home buttons together and then press the Power button until the device turns on. Now press the Volume Up button to enter Download Mode Step-5: Run Odin on the computer as an Administrator Step-6: Connect the Note to the computer using USB cable while it is in the Download Mode. Wait until Odin detects the device. When the phone is connected successfully, the ID: COM box in Odin will turn yellow with the COM port number. Also, the successful connection will be indicated by a message saying Added in Odin. If the Added message does not appear, then try the USB port located at the back of the computer. If that too does not work, then re-install USB Driver Step-7: In Odin, click the PDA button and select the CF-Auto-Root-to3g-to3gxx-gtn7100.tar.md5 file Step-8: Verify that the Auto Reboot and F.Reset Time checkboxes are selected in Odin. But uncheck the Re-Partition option Step-9: Double check everything and click the Start button in Odin. The installation should begin now and would take few minutes to complete Step-10: Upon the completion of the installation process, a PASS message with green background will appear in the left-most box at the top of Odin. The phone will then restart automatically. Once the home screen appears on the phone, unplug safely the USB cable from the device to disconnect it from the computer CF-Root Download Hotfile.com: One click file hosting: Odin3_v3.07.rar |
