07-10-2014, 10:24 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: Serbia Age: 42
Member: 4597 Status: Offline Thanks Meter: 36 | n7100 Unlock Failed!? [Solved] Selected port: COM1 Selected model: GT-N7100 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Nov 20 19:22:31 KST 2013 PDA version: N7100XXUEMK9 CSC version: N7100OXFEMK3 SW version: N7100XXUEMJ9 Phone IMEI: 355696059090296 Phone SN: RF1D24VWVJD Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-N7100 Detected phone model: GT-N7100 Firmware compiled date: Wed Nov 20 19:22:31 KST 2013 PDA version: N7100XXUEMK9 CSC version: N7100OXFEMK3 SW version: N7100XXUEMJ9 Phone IMEI: 355696059090296 Phone SN: RF1D24VWVJD Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-N7100-10-07-2014_11-18-06-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Unlocking phone. This can take some time. Please wait... Phone unlocking failed Why? Last edited by Octopus box; 07-10-2014 at 13:25. |
07-10-2014, 10:27 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Do the next: 1. Install the latest Software version (Software). 2. Take out SIM and SD cards from the phone. 3. Re-start the phone (also try to make Factory data reset). 4. Repeat the Unlock operation again. 5. Post here full Software log. |
07-10-2014, 10:46 | #3 (permalink) |
Member: 4597 Status: Offline Thanks Meter: 36 | Welcome to Octoplus/Octopus Box Samsung software version 1.6.0 ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-N7100 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-N7100 Searching for a phone. Please wait... Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM7 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Nov 20 19:22:31 KST 2013 PDA version: N7100XXUEMK9 CSC version: N7100OXFEMK3 SW version: N7100XXUEMJ9 Phone IMEI: 355696059090296 Phone SN: RF1D24VWVJD Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: GT-N7100 Detected phone model: GT-N7100 Firmware compiled date: Wed Nov 20 19:22:31 KST 2013 PDA version: N7100XXUEMK9 CSC version: N7100OXFEMK3 SW version: N7100XXUEMJ9 Phone IMEI: 355696059090296 Phone SN: RF1D24VWVJD Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-N7100-10-07-2014_11-41-04-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Unlocking phone. This can take some time. Please wait... Phone unlocking failed Not Work!! |
07-10-2014, 11:03 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to re-flash the phopne with another 4.3 firmware from the Support area and repeat the Unlock operation again. If the problem is still the, do exactly the next: 1. Re-flash the phone with another 4.3 firmware from the Support Area. 2. Make Repair EFS. 3. Make Repair IMEI. 4. Make Unlock. 5. Post here the result. |
07-10-2014, 13:14 | #5 (permalink) |
Member: 4597 Status: Offline Thanks Meter: 36 | Welcome to Octoplus/Octopus Box Samsung software version 1.6.0 ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. Selected firmware file: N7100XXUEMKA_N7100OJVEMK3 _N7100XXUEMJ9_HOME.oct Please switch your phone to the download mode and connect it to a PC. To put GT-N7100 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing TZSW section... TZSW section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-N7100 Searching for a phone. Please wait... Phone found. Firmware compiled date: Thu Nov 21 19:30:49 KST 2013 PDA version: N7100XXUEMKA CSC version: N7100OJVEMK3 SW version: N7100XXUEMJ9 Phone IMEI: 355696059090296 Phone SN: RF1D24VWVJD Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-N7100 Detected phone model: GT-N7100 Firmware compiled date: Thu Nov 21 19:30:49 KST 2013 PDA version: N7100XXUEMKA CSC version: N7100OJVEMK3 SW version: N7100XXUEMJ9 Phone IMEI: 355696059090296 Phone SN: RF1D24VWVJD Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-N7100-10-07-2014_14-10-52-.asec file Cheking security type... New security type is detected Executing exploit... Unlocking phone. This can take some time. Please wait... Phone will restart now Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) After flash successfully unlocked! Nice Last edited by ecsike; 07-10-2014 at 13:22. |
