05-01-2015, 10:15 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: albania
Member: 133415 Status: Offline Thanks Meter: 46 | n7105 imei problem INFO : 5/1/2015 10:45:16 AM > Selected port: COM1 INFO : 5/1/2015 10:45:16 AM > Selected model: GT-N7105 WARN : 5/1/2015 10:45:16 AM > To put GT-N7105 into Download Mode, You have to perform the following steps: WARN : 5/1/2015 10:45:16 AM > 1. Reconnect the battery. WARN : 5/1/2015 10:45:16 AM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 5/1/2015 10:45:16 AM > 3. When phone turns on, press "Volume+" key. INFO : 5/1/2015 10:45:18 AM > Repairing EFS... INFO : 5/1/2015 10:45:18 AM > Searching for a phone. Please wait... INFO : 5/1/2015 10:45:22 AM > EFS Repair successfully INFO : 5/1/2015 10:47:09 AM > ----------------------------------------------------------------------------- Welcome to Octoplus/Octopus Box Samsung software version 1.9.3 ----------------------------------------------------------------------------------- To connect GT-N7105 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+MODEM+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HSIC". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: GT-N7105 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM65 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Apr 14 2014 Firmware compiled time: 18:44:19 Firmware released date: Apr 14 2014 Firmware released time: 18:44:19 Incorrect IMEI SW version: M9615ACEHWMAZD179599 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM65 Selected model: GT-N7105 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Apr 14 2014 Firmware compiled time: 18:44:19 Firmware released date: Apr 14 2014 Firmware released time: 18:44:19 SW version: M9615ACEHWMAZD179599 Old IMEI: 004400-15-202000-0 New IMEI: 354792-05-663534-9 Creating NVM backup Reading NVM done! ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM65 Selected model: GT-N7105 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Apr 14 2014 Firmware compiled time: 18:44:19 Firmware released date: Apr 14 2014 Firmware released time: 18:44:19 SW version: M9615ACEHWMAZD179599 Old IMEI: 004400-15-202000-0 New IMEI: 354792-05-663534-9 Creating NVM backup Reading NVM done! ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM65 Selected model: GT-N7105 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Apr 14 2014 Firmware compiled time: 18:44:19 Firmware released date: Apr 14 2014 Firmware released time: 18:44:19 SW version: M9615ACEHWMAZD179599 Old IMEI: 004400-15-202000-0 New IMEI: 354792-05-663534-9 Creating NVM backup Reading NVM done! ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Fri May 16 14:20:54 KST 2014 PDA version: N7105XXUFNE3 CSC version: N7105VFGFNE1 SW version: N7105BUUFND1 Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as F:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-N7105-01-05-2015_11-08-29-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Apr 14 2014 Firmware compiled time: 18:44:19 Firmware released date: Apr 14 2014 Firmware released time: 18:44:19 SW version: M9615ACEHWMAZD179599 Found phone on COM65 Repairing NVM for GT-N7105 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM65 Selected model: GT-N7105 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Apr 14 2014 Firmware compiled time: 18:44:19 Firmware released date: Apr 14 2014 Firmware released time: 18:44:19 Incorrect IMEI SW version: M9615ACEHWMAZD179599 |
05-01-2015, 13:06 | #7 (permalink) | |
Member: 133415 Status: Offline Thanks Meter: 46 | imei now 0/00 Quote:
Welcome to Octoplus/Octopus Box Samsung software version 1.9.3 ----------------------------------------------------------------------------------- To connect GT-N7105 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+MODEM+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HSIC". 14. Restart phone. 15. Press "Read Info" in software. Selected firmware file: N7105XXALIJ_DTMALI5 _Germany_T_Mobile_Android_4.1.1.oct Please put the phone into Download Mode and connect USB cable. To put GT-N7105 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM62 Selected model: GT-N7105 Mode: Emergency Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM62 Selected model: GT-N7105 Mode: Emergency Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM83 Selected model: GT-N7105 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Sep 12 2012 Firmware compiled time: 13:00:00 Firmware released date: Sep 27 2012 Firmware released time: 15:12:44 SW version: M9615ACEHWMAZD179545 Old IMEI: 004400-15-202000-0 New IMEI: 354792-05-663534-9 Creating NVM backup Reading NVM done! ADB server killed. Firmware compiled date: Wed Sep 26 21:33:04 KST 2012 PDA version: N7105XXALIJ CSC version: N7105DTMALI5 SW version: N7105XXALIK Phone IMEI: Unknown Android version: 4.1.1 (JRO03C) Cheking Root Reading security backup, please wait... Backup saved as F:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-N7105-01-05-2015_14-03-11-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Sep 12 2012 Firmware compiled time: 13:00:00 Firmware released date: Sep 27 2012 Firmware released time: 15:12:44 SW version: M9615ACEHWMAZD179545 Found phone on COM83 Repairing NVM for GT-N7105 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) | |
05-01-2015, 13:16 | #8 (permalink) |
Freak Poster Join Date: Apr 2015 Location: IN INDIA
Member: 2372600 Status: Offline Sonork: 100.1663659,ICQ-670897523 Thanks Meter: 49 | HI, 1.Repair EFS. 2.Connect powered-on phone to PC via Micro USB cable. 3.Enter correct IMEI. 4.Click "IMEI fix" button. AND POST YOUR RSEULTS |
The Following User Says Thank You to Octopusindia For This Useful Post: |
05-01-2015, 13:36 | #9 (permalink) | |
Member: 133415 Status: Offline Thanks Meter: 46 | Quote:
----------------------------------------------------------------------------------- To connect GT-N7105 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+MODEM+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HSIC". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM25 Selected model: GT-N7105 To put GT-N7105 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Repair EFS was canceled Repair EFS was canceled ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM25 Selected model: GT-N7105 Phone was not found on the selected port! To put GT-N7105 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... EFS Repair successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM25 Selected model: GT-N7105 Port is busy Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM83 Selected model: GT-N7105 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Sep 12 2012 Firmware compiled time: 13:00:00 Firmware released date: Sep 27 2012 Firmware released time: 15:12:44 SW version: M9615ACEHWMAZD179545 Old IMEI: 004400-15-202000-0 New IMEI: 354792-05-663534-9 Creating NVM backup Reading NVM done! ADB server killed. Firmware compiled date: Wed Sep 26 21:33:04 KST 2012 PDA version: N7105XXALIJ CSC version: N7105DTMALI5 SW version: N7105XXALIK Phone IMEI: Unknown Android version: 4.1.1 (JRO03C) Cheking Root Reading security backup, please wait... Backup saved as F:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-N7105-01-05-2015_14-33-23-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Sep 12 2012 Firmware compiled time: 13:00:00 Firmware released date: Sep 27 2012 Firmware released time: 15:12:44 SW version: M9615ACEHWMAZD179545 Found phone on COM83 Repairing NVM for GT-N7105 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM83 Selected model: GT-N7105 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Sep 12 2012 Firmware compiled time: 13:00:00 Firmware released date: Sep 27 2012 Firmware released time: 15:12:44 Incorrect IMEI SW version: M9615ACEHWMAZD179545 | |
05-01-2015, 14:26 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Tomorrow we will try to prepare test Software version with Write Cert feature for this device and send You for testing writing IMEI Certificate. |
05-01-2015, 15:52 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Check your PM, we have prepared and sent You test Software version. Root the device, make Wipe Security and try to write IMEI Certificate from the Support Area. Post here the result. |
