12-31-2014, 17:41 | #1 (permalink) | |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | N900 - Repair Successful STILL no Network ! Quote:
12-31-2014, 18:51 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Do the next: 1. Install the latest Software version (Software). 2. Root the phone. 3. Write IMEI Certificate (we have sent You several to PM). 4. Insert SIM card. wait 5-7 minutes and try to find and select network manually. |
01-06-2015, 13:02 | #4 (permalink) | ||
Member: 64823 Status: Offline Thanks Meter: 439 | Quote:
01-06-2015, 13:38 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please download "Cert-SM-N900-358021057834883-00000000000.cert" cert file from "Samsung/FOR UNLOCK AND REPAIR/Certificates" folder of the Support Area and try to write it again. If problem will remain - close the Software and upload latest *.log and *.logx files from "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder and post here download link. |
01-07-2015, 12:25 | #6 (permalink) | |
Selected port: COM1 Selected model: SM-N900 Selected file: D:\--- MOBILE BOX\Octopus\samsung\n900\Cert-SM- N900-358021057834883-00000000000.cert ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N900 Firmware compiled date: Sat Jul 26 00:12:23 KST 2014 PDA version: N900XXUENG3 CSC version: N900OJVENG2 SW version: N900XXUENG1 Phone IMEI: 358021058399233 Phone SN: RF1D944VR1X Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed Log is attached @ | |
01-07-2015, 13:47 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Make Factory data reset and wipe cache partition, re-flash the phone, root it and write other IMEI Certificates from the Support Area. |
01-07-2015, 15:27 | #9 (permalink) | |||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As I see from your Software log, there different IMEIs in each log: Quote:
01-07-2015, 15:44 | #10 (permalink) | ||
01-07-2015, 15:51 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Ok, we will research, where can be the problem and say You the result. |
01-09-2015, 12:00 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Yes, we have prepared and sent You test Software version to PM. Try to write Certificate by using this Software and post here the result. |
01-10-2015, 09:58 | #14 (permalink) | |||
RESULTS below : Quote:
1. IMEI become : Phone IMEI: 004999010640000 2. It got SIM lock So i unlock: Quote:
Still Not network . When search manual keep Searching !!! | |||
