12-19-2014, 09:17 | #1 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | N900 Write backup Cert failed...... I have got one N900 .. It was hanging a bit so i flashed it with a firmware i had ....... But after flashing the Baseband got corrupted ..... Thankfully i had taken backup of its Efs, Sec, and Cert..... After flashing couple of different firmware from support and resetting Efs default i got The baseband back ..... But the imei was Default too..... As i had the cert backup, I tried Writing back the cert..... But While writing the Cert i get the following error.... Quote:
I even tried writing the backup EFS but after writing the Efs, Baseband again gets corrupted ...... Could support team help me revive This phone ? | |
12-19-2014, 09:37 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Before to write IMEI Certificate, do the next: 1. Make Factory data reset and wipe cache partition. 2. Root the phone. 3. Make Wipe Security. |
12-19-2014, 09:45 | #4 (permalink) | |
Member: 821646 Status: Offline Thanks Meter: 507 | Still fail to write Cert after factory reset and root.... Quote:
12-19-2014, 10:01 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have sent You EFS backup into PM. Try to write this EFS backup, then make Factory date reset, re-flash the phone, root it and try to write Certificate again. Post here full Software log with all of these actions. |
12-19-2014, 10:20 | #9 (permalink) | |||
Member: 821646 Status: Offline Thanks Meter: 507 | Write Efs You send..... Done. Quote:
After write this efs Unknown Baseband... Factory Reset data.... Done. Still Unknown Baseband.... Re-Flash Phone...... Done.... Quote:
Rooting phone ...... Done. Write backup Cert..... Still Error. Quote:
12-19-2014, 10:27 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to write different firmwares to repair baseband. When baseband will be repaired, try to write Certificate again. Also try to write one of the Services IMEIs from the Software list. Post here full Software log. |
12-19-2014, 10:33 | #12 (permalink) |
Member: 821646 Status: Offline Thanks Meter: 507 | Thanks for ur response brother.... I am able to repair Unknown baseband by Deleting the Efs folder from root .... And yes im able to write different cert and super Imei ..... But why am i not able to write the backup Cert ? any thing wrong in backup procedure ? |
12-19-2014, 10:35 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | No, this is because EFS and Security are damaged in your device, so the phone doesn't accept writing data. If You have the first original security backup, please write it into the phone and then write Certificate. |
12-19-2014, 10:40 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Repair baseband and write Security backup (it should be from your device, not from another SM-N900!), and post here the log. |
