10-11-2014, 10:38 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: England Manchester
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | N9005 cert write problem same. ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM427 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Apr 04 2014 Firmware compiled time: 16:00:00 Firmware released date: Jun 16 2014 Firmware released time: 09:44:23 Phone IMEI: 357507-05-009986-3 SW version: M8974A-AAAANAZM-1.0.180102A ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM427 Selected model: SM-N9005 Selected file: C:\Users\Ah$an Nawaz\Desktop\SM-N900_ 359092050091226_S200012760.cert Checking Certificate file... Certificate file successfully checked Connect UART cable Connecting to phone, please wait... Found phone on COM4 Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking for compatible Certificate and phone... Certificate is correct Certificate write successfully Please, restart the phone to apply changes I have N9005 with problem no service only when i check *#0011# phone show cert falid...M try write N900 cert on N9005 but problem same. |
10-11-2014, 10:41 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You need to perform "Repair Security/Wipe Security" operation before write Cert, in the opposite case, Cert will not be written and accepted correctly by the phone. |
10-11-2014, 11:05 | #3 (permalink) |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Welcome to Octoplus/Octopus Box Samsung software version 1.7.0 ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM427 Selected model: SM-N9005 Reading info, please wait... Detected phone model: SM-N9005 Firmware compiled date: Wed Jun 25 21:15:26 KST 2014 PDA version: N9005XXUFNF4 CSC version: N9005OXAFNF4 SW version: N9005XXUFNF2 Phone IMEI: 357507050099863 Phone SN: RV1D956TFKR Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM427 Selected model: SM-N9005 Detected phone model: SM-N9005 Firmware compiled date: Wed Jun 25 21:15:26 KST 2014 PDA version: N9005XXUFNF4 CSC version: N9005OXAFNF4 SW version: N9005XXUFNF2 Phone IMEI: 357507050099863 Phone SN: RV1D956TFKR Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N9005-357507050099863-11-10-2014_15-02- 05-.asec file Wiping EFS... EFS wipe successfully Phone will restart now Still Imei Certi : FAIL |
10-11-2014, 11:17 | #5 (permalink) |
Freak Poster Join Date: May 2005
Member: 149004 Status: Offline Thanks Meter: 14 | first restore the phone with first original security backup, then backup your qcn, wipe efs, write new cert. write back qcn, if you get error, at the end qcn writing, wipe manually the phone, volume up + home + power. Br Ice |
10-11-2014, 15:43 | #8 (permalink) |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | M try this but still same problem.....some time phone show emergency call only and again show no service......without sim phone show no service. |
10-11-2014, 17:26 | #9 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
I think you have done any mistake, Br allumts | |
10-13-2014, 14:40 | #14 (permalink) | |
where have take these steps?....i not understand becouse not read my CLEAR procedure Step by step here: Important note!! About "read/write cert" and "wipe efs" Open the "Spoiler", "Click for open" button, not is complicate. Try with exact step one by one. BR | |
10-14-2014, 12:13 | #15 (permalink) | |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | N9005 No Service Quote:
Thanks...for ur sharing info....M Done other phone N9005 with same problem...This One phone not ok..with This. | |
