01-24-2015, 10:05 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | The problem is You have not configured the device correctly. Phone's info should be read out fully and correctly, not as in your log. To connect SM-N9005, carefully perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. When phone's info will be read out fully and correctly, make Wipe Security. |
01-25-2015, 12:47 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Also, as You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) make Wipe EFS. | |
01-29-2015, 18:29 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Support Area contains only original Samsung firmwares. Please don't use any download managers for downloads from Support Area. Try to download the files via browser. |
01-30-2015, 14:51 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please contact us to Skype, Yahoo! Messenger or ICQ, we will check remotely, where can be the problem with downloading from your side. Our contacts You can find in our profile. |
