06-13-2014, 12:55 | #1 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2175448 Status: Offline Thanks Meter: 0 | n9005 imei fix for now I'm using it with imei efs professional service written with and without cable uart. Use the 'octopus to rewrite the' original imei and tells me to use a imei compatible with your phone model, why?? but if I try to write imei of service with an octopus cable uart ask me why? connect the cable uart but written out: phone and try not to be is not that my box is broken? if you can fix? |
06-13-2014, 17:43 | #3 (permalink) | |
Member: 2175448 Status: Offline Thanks Meter: 0 | Quote:
1 I open the software octopus I run 2 porcedura * # 8080 # and put it on the 'last option 3 connect my sm-n9005 with usb cable to the box 4 door as I put com9 5 I move on repair imei and I click on read info 6 I get: Platform: Samsung Android Selected port: COM9 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Dec 19, 2013 Firmware compiled time: 11:00:00 Firmware released date: Feb 3 2014 Firmware released time: 16:10:34 Phone IMEI: 3575 ** - ** -000003-6 SW version: M8974A-AAAANAZM-1.0.180102 -------------------------------------------------- ----------- imei and service 7 change imei entering my ****** 351 776 3/6 8 I click on imeia fix 9 out Platform: Samsung Android Selected port: COM9 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Dec 19, 2013 Firmware compiled time: 11:00:00 Firmware released date: Feb 3 2014 Firmware released time: 16:10:34 SW version: M8974A-AAAANAZM-1.0.180102 Old IMEI: 3575 ** - ** -000003-6 New IMEI: 3517 ** - ** - **** 23-6 Please select service IMEI for this phone model Write IMEI failed my imei and the right one. | |
06-13-2014, 17:49 | #4 (permalink) |
Member: 2175448 Status: Offline Thanks Meter: 0 | After this I try to write imei of a service but .... 1 I click on a random imei 2 fix imei Platform: Samsung Android Selected port: COM9 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Dec 19, 2013 Firmware compiled time: 11:00:00 Firmware released date: Feb 3 2014 Firmware released time: 16:10:34 SW version: M8974A-AAAANAZM-1.0.180102 Old IMEI: **** New IMEI: **** Creating NVM backup Reading NVM done! Connecting to ADB, please waite ... Firmware compiled date: Wed February 12 17:24:44 KST 2014 PDA version: N9005XXUENB4 CSC version: N9005ITVENB1 SW version: N9005XXUENB1 Phone IMEI: ************* Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Cheking Root Erasing old IMEI. It can take some time. Please wait ... Reading security backups, please wait ... Backup saved as C: \ Program Files (x86) \ Octoplus \ Octoplus_Samsung \ BACKUP \ Security-SM-N9005-357507050000036-13-06-2014_18-45- 40-.asec file 3, the phone will restart 4 Out USB cable 5 Connect the cable uart GT-C3300K 6 I press ok 7 Phone will restart now. Please do not disconnect cable! Phone rebooted after being powered on and perform the Following steps: 1. Disconnect the USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the box. Serching phone ... and remains so for hours |
06-13-2014, 18:24 | #5 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
\ BACKUP \ Security-SM-N9005-357507050000036-13-06-2014_18-45- 40-.asec file) into the phone, re-flash the phone and try to repeat operation by using other Samsung Micro UART C3300k/C3303k cable with 523-525 kOhm resistor inside, most likely, the problem is with cable. Also try to use another Box as UART interface. | ||
06-13-2014, 18:29 | #6 (permalink) | |
I have to buy a cable x 3 notes give me a link? so I can only write the imei service? | |
06-13-2014, 19:16 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | In most cases such problem is solved by using a another Samsung Micro UART C3300k/C3303k cable with 523-525 kOhm resistor inside. Sometimes using another box as UART interface also helps. Yes, currently You can only write IMEI from Software list (service IMEI). |
06-13-2014, 19:34 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please, contact to our managers in on-line Sales Chat at GsmServer, they will help You. Last edited by Octopus box; 06-15-2014 at 08:27. |
06-13-2014, 20:23 | #10 (permalink) | |
maybe around the cable kit thanks Last edited by Octopus box; 06-15-2014 at 08:28. | |
06-15-2014, 08:27 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | No, currently, not solution or Box that can write original IMEI and make network available (You can write any IMEI, but network will be inactive). |
06-15-2014, 09:01 | #13 (permalink) | |
thanks for the replies. in the future should something go out? xche with imei service occasionally block the network How can I test my octopus box? | |
10-03-2014, 01:28 | #14 (permalink) |
Junior Member Join Date: Sep 2014 Location: texas
Member: 2266243 Status: Offline Sonork: Xifi Thanks Meter: 1 | Platform: Samsung Android Selected port: COM3 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: NO IMEI NO BASEBAND ANY HELP ? |
10-03-2014, 01:52 | #15 (permalink) |
Member: 2266243 Status: Offline Sonork: Xifi Thanks Meter: 1 | Welcome to Octoplus/Octopus Box Samsung software version 1.6.7 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Connecting to ADB, please waite... Firmware compiled date: Tue Aug 12 11:28:16 KST 2014 PDA version: N9005DXUGNH1 CSC version: N9005OLCGNH1 SW version: Unknown Critical error has encounted. Error message: List index out of bounds (2) |
