08-26-2014, 12:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | n9005 unknown baseband.. i wish to update 4.3 to 4.4.2 but it give fails then i flash it with pit 32 gb after flash it give memory error .i reset it and then it turns on but now baseband is unknown and imei null any idea what to do? |
08-26-2014, 12:58 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
08-27-2014, 16:16 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | It is impossible to say, which firmware will help to solve the problem, try to write different, one by one and check. |
08-27-2014, 16:25 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | You can try to write via any tool You have. Try to write the latest firmwares, don't downgrade the firmware version, this can damage your device. |
08-27-2014, 20:39 | #8 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Flash After has flashed other full fw, NOT flash N9005XXUGNG1 Br allumts | |
08-29-2014, 13:53 | #9 (permalink) | |
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | Quote:
can i flash this file after write any firmware or some specific firmware? and when i write firmware.can i write one file or full 3 files ? and if i flash 3 files.after that write this modem or overwrite this modem to fw modem? | |
08-29-2014, 14:00 | #10 (permalink) | |
can i write some specific firmware for this file and if yes then plz specify me firmware . and also mention firmware with 3 files or 1 file thanks | |
08-29-2014, 14:08 | #11 (permalink) | |||
No Life Poster Join Date: Mar 2005 Location: tuttotelefonia
Member: 125945 Status: Offline Thanks Meter: 495 | @MYUNLOCKING, Quote:
This is when partition are been damaged from wrong flash fw, in 3 device has worked, cannot know if can solve you problem but is one attempt. Br allumts | |||
08-29-2014, 14:47 | #12 (permalink) |
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | can you plz give me link for 3 files? i have wirte single files .and after modem but still no change now can i write 3 files? |
08-29-2014, 20:27 | #13 (permalink) | |
If not has worked also with one package, try to EFS repair, but OCTOPUS not support, for the moment, this option so or try with another box or wait for Update Octopus team, Br allumts | |
08-30-2014, 11:19 | #15 (permalink) | |
P.d. Please NOT forgot solution for Last Samsung Fw that not permitte 3G/4G with "IMEI CERT FAIL" Br allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
