04-24-2015, 00:07 | #1 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Honduras
Member: 1353903 Status: Offline Sonork: 100.1659096 Thanks Meter: 92 | N900a unlock done ----------------------------------------------------------------------------------- To connect SM-N900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N900A Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM30 Mode: Normal Phone model: SM-N900A Firmware compiled date: Jan 29 2014 Firmware compiled time: 07:00:00 Firmware released date: Mar 15 2014 Firmware released time: 14:55:10 Phone IMEI: 358579-05-XXXXXXX SW version: M8974A-AAAANAZM-2.0.10025 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM30 Selected model: SM-N900A Reading info... Mode: Normal Firmware compiled date: Jan 29 2014 Firmware compiled time: 07:00:00 Firmware released date: Mar 15 2014 Firmware released time: 14:55:10 SW Version: M8974A-AAAANAZM-2.0.10025 ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N900A Firmware compiled date: Sat Mar 15 17:48:27 KST 2014 PDA version: N900AUCUCNC2 CSC version: N900AATTCNC2 SW version: N900AUCUCNC2 Phone IMEI: 3585790XXXXXXXXXX Phone SN: R38F40G0ANR Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Last edited by Octopus box; 04-24-2015 at 06:24. |
